1976 Toyota Hilux SR5
Discussion in '1976-1983 Build-Up/Project Threads' started by Danica, Sep 17, 2018.
  1. Danica
    Danica Newbie
    Arizona
    1976 Toyota Hilux SR5 Shortbed
    Hi all, just got myself a 1976 Toyota SR5. Everything is all stock from the engine to the suspension. I really want my truck to go lower and look slammed, but in need of some help and advise. Also, I am thinking of swapping out the oem carburetor with a Weber carb from LCE..any feedback on this? and possibly what I need to do with the engine (camshaft size, headers, etc.) in order for me to do this? I'm pretty new to this so please bare with me. Hope to hear some feedback's and advice.
  2. jetas
    Looks like its a clean truck
    Be aware, if you have emmisions testing the weber may not pass a visual. Otherwise, swapping a Weber on is just that, no other mods necessary
  3. nottoshabi
    nottoshabi Enthusiast
    Damn that is clean. Nice truck. I have lowered (slammed) my truck 5" in the rear and 3.5" in the front. You can read all about it here. The pic links are broken but I go into a lot of detail of parts and what to do. I also recommend changing all ball joints, pit arms and steering box while your in there. Mine had a lot of play in it when I bought it so I needed to change them.
    jetas likes this.
  4. Danica
    Danica Newbie
    Arizona
    Thank you..and no emissions testing from my area..what size weber would you recommend as a daily driver?
  5. Danica
    Danica Newbie
    Arizona
    Thank you!! I'll definitely read into your thread. You guys are awesome!
  6. jetas
    Most people do the 32/36. Got it on mine, seems fine
  7. Danica
    Danica Newbie
    Arizona
    I guess I'll make mine a 32/36. I've been watching a built on IG as well. Check out @orangeluxx he has an awesome 1975 built.
  8. nottoshabi
    do you have a part number? and what type of filter?
  9. jetas
    Yea i follow him on IG. Clean truck
  10. Danica
    Danica Newbie
    Arizona
    By the way, which one would you recommend with the Weber carb.. i'm on LCE and there are two different kinds - electric choke and manual choke.
  11. Danica
    Danica Newbie
    Arizona
    For which?
  12. nottoshabi
    Weber carb for a 78 and air filter.
  13. Danica
    Danica Newbie
    Arizona
  14. jetas
    I got the one with the electric choke.
  15. nottoshabi
    What is the difference between the electrical and manual choke, beyond the obvious? Is an electrical choke better for performance or gas consumption?
  16. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    I'd say it's more of a convenience thing.
    jetas likes this.
  17. Danica
    Danica Newbie
    Arizona
    So I've been reading on some others thread on what to do to lower our year and model trucks (1973-1978). So I've read and also watched a youtube video of either cutting the front springs 3 inches or getting a mighty max coils (while at it replace the shocks and ball joints) and for lowering the rear; remove bump stops, remove center leaf spring, and put 3 inch lowering blocks (while at it replace the shocks as well).
    What do you guys think? What have you read or done?
  18. nottoshabi
    I have done the mighty max springs replaced shocks and ball joints. And in the rear I bought lowering leaf springs from summit racing also replaced shocks and removed bump stops. In the rear I did not want to remove a leaf spring because I want to be able to haul stuff with it.
    Here is the down fall with lowering the front with the mighty max springs and Ks shocks they will really lower the truck I have about 3 inch clearance and i'm hitting the frame also its very jumpy it is not a smooth ride at all. When I first lowered it I had the sway bar installed then I hit something and broke the bracket the holds the sway bar to the frame I had to take the sway bar out as I need to get the piece re-manufactured cause you can't buy that at the store any more. So the truck sits 2" lower then when I first lowered it. I live in LA and the roads are not so smooth here I have to travel at least 30mph to be able to absorb the bumps otherwise im hitting the frame. Going over speed humps/bumps i have to crawl other wise the truck jumps up as the A arms hit the frame and launch the truck in the air. Im finding out the combo of the mighty max and KS shock are to soft for this truck. Im going to add the sway bar and bump stops in and this will raise it 1.5 inches to be able to have more space for the shocks to absorb the bumps. Things are rattling apart in the truck the dash and instruments im constantly tightening and adjusting. Maybe the stock springs are stronger and can handle the weight a bit better and cutting a coil or 2 to lower it will be better absorbent then the mighty max springs.
  19. jetas
    So on mine i cut the stock springs(3 coils) new BJs and old shocks, no sway bar. Rear is a 3" block, 1" bolt on beefed block and pulled the middle leaf. Got about 2" of axle clearance and maybe 4" from the ground at the engine x member. Ride is terrible compared to the new cars we have
  20. KS.ID
    KS.ID Enthusiast
    Bay Area, CA
    RN22 1972 Hilux
    Could you shed some light on the Beefed Block? This is to maintain a proper angle on the drive shaft correct?
