^^^ those are true as ****! ...when a gauge install means its sitting in the stereo hole ...when a gas station attendant looks at you funny because you wanna put super in a crappy little orange truck ...when fat girls get mad at the clearly posted rule between the seats "no fat chicks, the truck will scrape"
..... when people look at you wierd when you go to the inside of the bed end not the "stock" filler locayion to fill with gas. ..... whan you have a modified version of the sticker "no fat girls truck will scrape" reading "........ no really, it really will scrape"
...when you used a 3/8" cordless impact gun to change your license plates By the way, that hole under the window is going to be my camera mount. 1/8" NPT plug (actually about 3/8" diameter) thats drilled and tapped for 1/4-20. Then I have a 6" length of 1/4-20 all thread that goes into the camera at one end, and the cab at the other. I bent a 90* into it. About as simple as it can get folks. When I decide to run twin cams (one out the window, one at the gauges: edit to be picture in picture) I will just replace the plug with a T fitting, and have 2 of the same setups off each side with an extra 90* bend sideways to go into that. Doing it from junk I had laying around.
sounds like you need an alignment bad........ it shouldnt toe out like that. Cin.... you want your stuff to be straight right?
Remember guys hes a kid, he aint fully developed yet. Give it a few months and wel have to check back on his condition....
....... if that ^^^ happens....... ....... if you go off topic on a forum but everything mentioned or therefore illustrated still relates.
...if your thread in the "off topic" page, goes off topic even further ...if you are reading about LED pulse width modulation so you can match stock gauge lights to your multicolor aftermarket ones
I'm trying to match the volt/oil/water/AF I'm installing to the Celica speedo/tach/fuel. ...if you refuse to spend as much on those 3 gauges I'm keeping as the truck cost; due to the fact I don't own a GM.
.... if you try to keep your project on the beer taste but water budget, forget about the budget and just go get drunk instead.....
....When u <3 BOOBS ...U get paranoid when anyone comes up and looks at your truck. ...When u double check that u double checked if you locked your truck and the most obvious, ...........when you drive a mini truck
when you drive by a big glass building with reflective glass and almost crash because you wanted to see how your truck looks rolling down the street with a new set of rims
