Yotarip's Turbo Truck - " Project Rebirth "
Discussion in '1984-1988 Build-Up/Project Threads' started by yotarip, May 9, 2008.
  1. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    so the 22ret was not much fun ????
    I am pretty sure a trubo will make me pretty happy
    only issue I find with the mk3 sub is it might make the truck sit high ?
  2. yotarip
    yotarip Veteran
    My 22ret was very fun. The guy I sold it to is having a blast with it in his celica. A 22ret with a turbo upgrade and standalone would be awesome.
    I prefer the 1uz because they are a dime a dozen here, very reliable, put down power without drama and sound awesome with the right exhaust.
  3. NashMan
    NashMan Toyotaholic
    94 2wd
    only part I don't like about the swap is how much it cost's to go 5 speed geeeeeeeeeeeeezzz talk about over priced
  4. IronNam
    most 1UZ->W5x adapters are roughly $1000 or less.
    I'd rather produce reliable power from a 1UZ or any Toyota V8 than to push more power out a 22RE/RET, regardless of how much power you can make. Standalone on a 22RE would cost you roughly $1000 to boot if you find a system cheap enough. At that point, you're going to lose a ton of reliability from the 4-cylinder if you push it that far, when the 4.0L V8 would make that power, with no addons.
    Consistency.
  5. NashMan
    NashMan Toyotaholic
    94 2wd
    Funny part is the sprint 500 cost a little under 1000 and can be used on a toy v8 if I choose to go that way....and lex v8 swap might as well do r154 at the same time since it will help with weight.
    but in the end I have stuiped dumb fast car all ready.. so haven a truck the same way is kinda point less... so 200 hp and I would be happy and doing that in a 22re and can be done all day long.
    if I was to do a swap thou I still have the 3 rotor n/a in the back of my head
  6. yotarip
    yotarip Veteran
    So,
    Over the weekend I visited one of our local junkyards that has a 85 4x4. I've seen it a few weeks ago but never walked over to investigate because I could see from a distance that it was just a frame and stripped cab. Lately I have wanted to swap out my sliding rear window for a solid window so I went to check out this old 4x4 that has been sitting there for weeks. Unfortunatley it had the same sliding window I have BUT it had the SR5 cluster! Scored it for $8 bucks.
    Took it home, added super white leds and wired up the Tach.
    The tach works perfectly with the 1uz because the 1uz's tach signal is the same pulse as a 4 cylinder.
    In other news, a few days later my front crank seal gave up the ghost. It's leaking oil like BP in the Gulf. Luckily, I was only 2 miles from home when it started. Gonna swap in a new seal tonight.
  7. yotarip
    yotarip Veteran
    Gonna remove the redundant oil and temp gauges I have installed in the radio pocket and mount a cupholder from ebay there. I will mount the aftermarket temp gauge in the pillar pod but it will monitor oil temp.
  8. NashMan
    NashMan Toyotaholic
    94 2wd
    ya get thous spec's yet for the brakes ????
  9. yotarip
    yotarip Veteran
    My bad dude. I'll check tomorrow. The oil leak threw my game off.
  10. Fabian
    Fabian Newbie
    Puerto Rico
    86 SR5 pickup extra cab turbo.
    where did you get the LED lights?
  11. yotarip
    yotarip Veteran
    Hey Nash,
    The caliper clears the rotor hub by 3/4"
    Sorry it took so long. Had two serious vehicle issues that needed my full attention.
  12. yotarip
    yotarip Veteran
    I got them from ebay. Search led T10 bulbs. You could get them for as little as 7 bucks for 20 lights.
  13. NashMan
    NashMan Toyotaholic
    94 2wd
    I ment the outer rotor disk to caliper slot sorry I should have been more clear
    thanks thou that does give me one goo mesher ment
  14. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    What caliper/rotor combo is that? Nissan 300/350 parts I assume? Can't find the post covering it. They look about as big as a 16" will allow. I have a 4runner caliper and 12.6" town car rotor combo. Clears 16s.
  15. NashMan
    NashMan Toyotaholic
    94 2wd
    ^ that what I am trying to figure out, looks like have it but I just need that one measher ment from him
    then I may make some brackets up
  16. yotarip
    yotarip Veteran
    The rotors are from a 1994 mazda mpv (rwd) and the caliper is a 300zx z32. The pads fram a 94 landcruiser contact the rotor surface perfectly. Setup works very well.
    Here is a crappy in cab video of a highway merge.
    <iframe width="420" height="315" src="//www.youtube.com/embed/5h2JBG_ttmo" frameborder="0" allowfullscreen></iframe>
    Didn't fully get on it because it has developed some very nasty wheel hop. Found out yesterday that I have a bent lower leafspring on the passenger side. Don't know haw it happened.
    Will get some outside video of the truck very soon. My hooning partner has been working alot of hours and doesn't have the time.
  17. Muttley81
    Muttley81 Newbie
    love your truck man i started to tweak my truck im stuck on tranny swap 4/5 speed issues but i want the same set up as yours. I hope you dont get offended by copying your setup anyway nice truck
  18. yotarip
    yotarip Veteran
    ^ Thanks.
    No offends at all. I share info on my builds to help others out.
  19. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    dang hearing the vid makes me wish i did a manual trans.
  20. IronNam
    Sounds freaking great, bro!
