Do you have one or know of anyone that does? I'd be interested! I'm looking for the kind that takes the stock clutch and pressure plate as I understand there are very lightweight ones that require a different set up. I don't want that. I just want a stock clutch with a lighter (15lb.?) flywheel. Thanks, Chip Morton [email protected] San Diego, CA
I know people that have taken the stock flywheel to the machine shop and had it shaved down to 17lbs and run a stock setup with no problems. I plan on buying the lc flywheel and clutch when I install my W58 though
I run the LC 9 1/2 lb. & their Pro Street clutch. Works very well,no problems, 20,000 miles on it now.
Dang! Thanks all. I didn't realize it was possible to machine that much material off. Is it something that pretty much any auto machine shop should be capable of doing?
not sure about that, I probably wouldnt go below 14 but I have no knowledge just my gut tells me not too.
Thanks, guys! After a little digging around I found this place that some people on some other boards speak well of. http://www.racetep.com/flywheel.html I'll get in touch with them.
