Who has the lowest 84-88????
Discussion in 'Suspension/Chassis' started by skip, Oct 26, 2007.
  1. NotAvailable
    NotAvailable Addict
    nah get some extra cabs running 5inhc blocks and remove bottom leaf for that little extra drop. i think if ur truck has the carrrier bearing type of drive shaft you should be safe...alot of people have the driveshaft problem with the one solid driveshaft. lmk bro i can help u out with ur bridge stuff and what not...maybe even do a mini C and slam it alot!
  2. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Nah i dont think i want a c notch. And ill go check about what kinda drive shaft i have. You know anyone selling 5" blocks?
  3. NotAvailable
    NotAvailable Addict
    no i would just get steel blocks from 4wheel parts hawaii in waipahu industrial..like 80 bucks i think tho...but its new so cant go wrong..if you do a mini c you will have a better ride. because you get more play:cool: lmao...ut watever floats ur boat.
  4. oahu grown
    Hawaii
    92 Extra Cab
    Yeah i talked to DH about doing a mini C for me couple days ago actually. Ill see how the ride is first before i commit to anything else. My old truck i never trimmed rear bumpstops, just put good shocks and that was good, so we see. Its all trial and error. And as bernie said, in order to go low you cant be afraid to chop **** up. ahhahahaha
  5. NotAvailable
    NotAvailable Addict
    yeah how much was dh gonna charge u for the mini c?....prolly 500 or so?
  6. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    notching the frame does not have an adverse effect on ride quality....... your ride quality (compression rate) stays the same, it just makes it to where it wont bottom out on the frame.
    if you wanna see it a different way, it actually improves the ride quality since it wont bottom out anymore where there were times it would.
  7. IronNam
    Exactly. it gives it extra room, or even extra travel!
    put it this way, Stock has about ~6" of travel. I'm not being super exact, but you will understand.
    then I put 3" drop blocks on there. I lose 3" of that travel. I have only about 3" of suspension travel, Which isn't bad at all at this point (considering that i already took off my bumpstops).
    So i decided to go even lower, an extra 2" . at this point, i have 1" of travel.
    every bump, im slapping frame and axle, rides like shiot.
    then i get a c-notch, there's a variety of sizes out there, but i'm going for a 4" notche.
    i get 5" of travel again :D
  8. SD YOTA
    let me clear on this that he meant up travel and not total emulsion travel. :waytogo:
  9. NotAvailable
    NotAvailable Addict
    i just ment travel because ride quality is effected by bottoming out on the frame thats what i ment..im not getting technical with spring rates and stiffness etc. because mainly when you drop ur truck alot the main reason ur ride will suck is because you bottom out..and the c notch will help give you extra travel and more travel so you dont bottom out.
  10. SD YOTA
    bingo! :waytogo:
  11. IronNam
    xcab's done need the cross member cut, single cabs do.
    i guess we have our notch discussion covered? lol
    so yeah, summarization of c-notches.....
    More travel = less bottoming out! :D
  12. NotAvailable
    NotAvailable Addict
    and less bottoming out= better ride.
    yeah extra cabs have the carrier bearing driveshaft so you dont needa cut.
  13. planemos
    planemos Toyotaholic
    British Columbia
    But you still need to correct driveline angles with an extra cab. A carrier bearing flip or cutting and raising the carrier bearing crossmember can help. I used a slip spline driveshaft from a 4x4 tacoma (static drop).
    You need to find the ideal driveline angle and go from there.
  14. Gr8KornHolio
    Gr8KornHolio Veteran
    Dallas, TX
    85 regular cab longbed 22R
    I really like the look and stance. What tire combo you running?
  15. pig rig
    pig rig Enthusiast
    bow washington
    I'd say a 195 or 205 50 15
  16. Metal worx inc
    Metal worx inc Newbie
    Hope Mills
  17. Enemy of the State
    Enemy of the State Enthusiast
    1985 xtra cab
  18. BigJose352
    BigJose352 Newbie
    Central,Florida
    1995 Taco
    Sick ass 86
  19. codybourgeois88
    codybourgeois88 Newbie
    filer idaho
    1988 toyota pick up
    hey i know this sounds dumb but thats the color i want my truck what is the code for it
  20. 94Yota_05CBR1K
    94Yota_05CBR1K Veteran
    San Diego aka SD, Daygo. Cali
    94 YoTa Mini 2wd
    I agree on adjusting torsions is the wrong way to lower your truck. Mine rides terrible and threw the alignment way off. Can't wait to get control arms or spindles.
