Which Weber?
Discussion in 'Engine/Drivetrain' started by project_DragTruck_v2.0, Oct 8, 2009.
Which Weber would YOU buy, and why?
  1. 32/36 DGEV
    66.7%
  2. 34/34 DGEC
    4.8%
  3. 36 Synchro
    0 vote(s)
    0.0%
  4. 38 DGES
    28.6%
  1. project_DragTruck_v2.0
    project_DragTruck_v2.0 Veteran
    Just a shot in the dark here, but I´m thinking probably 5.29 gears....
  2. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    30mpg w/ 35's
    32/36
    2in carb spacer
    offy dual plane intake
    doug thorely tri y header +2.25 exhaust n quiet stock type exhaust.
    91 22re grey hi-density coil
    bosch +4's
    NGK (i think) blue wires
    lots of static advance
    4 speed
    4:10's
    32psi in tires
    stock long block w/new gaskets
    now this is crusing steady on a flat 140mi round trip that took me less then 5 gallons. im turning about 2.7k @ 60mph barely touching the throttle. with 5.29's id be near 3.5k
    around town i get closer to 20, the starts and stops kill the mpg and im not one to drive slow.
    this truck
    this motor
  3. KK082409
    KK082409 Enthusiast
    Pasadena, CA
    88 single cab
    Im looking for a truck like that so I can make it into a rock crawler... looks great
  4. project_DragTruck_v2.0
    Ahhhhh, the only reason I thought 5.29s was because a friend of mine had an 88 on 35ś with a 20/22r and a five speed, thatś about similar mileage to what he got with 5.29ś
  5. johnpaul
    johnpaul Member
    no la
    92 xcab 2.4
    i had the same carb on my mighty max and it worked great
  6. 22r
    22r Veteran
    Maui
    on lc engineering theres a stock modified carb its kinda intresting (unless you live in cali). id like to try and run it, sounds pretty sicckk.
  7. RandomHumanBein
    RandomHumanBein Member
    Charleston, SC
    '88 Base model
    i already bought a weber 38. i have a 2wd with a 4 speed and if i keep it 55 mph on the highway im capable of 27 mpg.
  8. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    if you jet the carb its capable of better, if you dump more fuel than air and your motor doesnt use it whats the point.:waytogo:
  9. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    for a motor thats near stock and stays there a 32/36 is great. if you plan to do head work, exhaust, ignition, ect...id suggest a 38/38. now this is assuming each is jetted for the motor and not base jetting. for me, i learned this after id already bought a 32/36 new from weber. i have a pace setter header with 1-5/8 primaries and its a 4-1 type. 2-1/2" collector. same size system. 8.5mm wires. autolite plugs. new dist, blaster 2 coil, ect. i took my airpump and a/c off. ported the hell out of a non egr intake i got from a celica. i also cut the choke horns off the carb. the head has bigger exhaust valves and a fresh rebuild. also have a 5 speed and 4.10s. it runs like a champ but 5th starts to lose pulling power over 100. it runs out of gear about 125.
    now had i known before i would have probably gotten the larger carb and jetted it right. and jet it to what i need. side drafts would be nice. but if i build for much real power ill probably do a 5/7M swap and just clear up the air path (intake, exhaust, ect) and keep it simple so i dont put too much wear and tear onto the motor.
