which drop spindles
Discussion in 'Suspension/Chassis' started by tomato, Apr 19, 2013.
  1. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    I didn't see "bell tech" anywhere on mine. Just the same "2000"
  2. tomato
    tomato Member
    palmyra, missouri
    92xcab-904x4-05taco-76fj40
    Thanks man, and yes 18x8 +42... And boy they are close to frame wheel well out back, but they clear
  3. patrickgraven
    patrickgraven Veteran
    Corona CA
    93 2wd pickup "home depot" / 2004 Toyota Sequoia 4x4
    I went to install them yesterday and found all the belltech paperwork in the bottom of the box. So I feel fairly certain that
    They are belltech spindles (bought a set before from stillen and look the same).
  4. tomato
    tomato Member
    palmyra, missouri
    Appears they are belltech. #2000 cast in the back side.
  5. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
  6. Xs5875
    Xs5875 Addict
    Greenville, Ga
    That them. Gonna have to adjust your steering stops too. I ran mine all the way in against the jamnut. You got tires on the motegis yet?
  7. tomato
    tomato Member
    palmyra, missouri
    No tires yet, but soon. i was rubbing pretty hard on the inner fender up front with 215/65-15s before spindles. might go ahead and cut em before i take it off the jack stands. pretty sure I'm gonna run static for this season and bag/body in the winter...
  8. saul22019
    saul22019 Member
    Las Vegas
    93 xtrcab, long bed
    i purchased those spindles from eBay. once i installed them i had to adjust the toe-in. i also had to find some bolts for the turn stops. its worth the buy, no defects or odd **** on them.
  9. tomato
    tomato Member
    palmyra, missouri
    ^^yep. they fit good,but ya gotta toe it in. my front end doesnt appear to have been apart since 92, so spraying them down didnt cut the mustard. gonna heat the adjuster sleeve a bit that should do it (fingers crossed). tires will be in tomorrow!
  10. Xs5875
    Xs5875 Addict
    Greenville, Ga
    I ended up putting the closed end of a wrench over the part of the tie rod end that goes into the spindle....thus creating a handle for leverage...Once it broke free, I threaded it all the way in, and all the way out.spraying WD40 the whole time...and rusty, grease was pouring out as I did this.
    Much betta now.
  11. tomato
    tomato Member
    palmyra, missouri
    Yep...i need bags.
  12. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    looks very good. the color of your truck and the wheels go very nice. whats next of the list?
  13. Xs5875
    Xs5875 Addict
    Greenville, Ga
    4x4 fenders I'd say lol.
  14. tomato
    tomato Member
    palmyra, missouri
    ^^and some tubs...
  15. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Thanks for this guys... Just the information I needed. I just ordered the last set I think.
  16. Tuhd The Troll
    Tuhd The Troll Veteran
    Houston, TX
    1982 SR5
    For some reason I thought you already had a set of drop spindles.
  17. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Nope, just lowering LCAs and cranked down torsion bars. Now I'm legit. Hey do you think you can play with photo shop for me a bit? I think I've finally decided what I am going to do.
  18. Tuhd The Troll
    Houston, TX
    1982 SR5
    Yeah, I can totally do some photoshopifying. I'll PM you my email and new phone # so we don't derail the thread too far.
  19. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Did any one that had these spindles have any play on the lower ball joint? The aftermarket ball joints that came with my KBS (cando) arms have a washer but it seems to still have some play. Seems like the castle nut is bottoming out on the ball joint before it touches the top of the hole for the lower ball joint that's on the drop spindle.
