Wheel fitment
Discussion in 'Wheels/Tires' started by Ivey, Feb 9, 2021.
  1. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Alright looks like I could try running a 165/45r15...
    edit: bought a set of 165/50r15, full send.
  2. smooov1
    smooov1 Newbie
    South East Washington
    1975 RN23 short bed
    It is, $90 per wheel and about the same per tire. I found the wheels on Amazon for $60, maybe Ill go that route.
  3. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Here is what it should look like.
  4. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Did you check with the shop? A lot of shops these days won't tretch tires that extreme for liability reasons.
  5. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Les Schwab is off the table but yeah I got a place down the street that don't give a fuck.
  6. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Better fitment pics. I’m pretty sure it will clear on the 165/50 but there might be too much of a gap. I’ve got room to go lower though. I think I’ll be dropping the front a little more at the very least. Next update I’ll have rubber on steel.
  7. jetas
    Il definitely recommend rolling your fender lips. Not necessarily a pull but at least a roll
    Ivey likes this.
  8. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Yeah I’m considering running a 1” rake, so drop the front another inch and then not stretching the rears only the fronts and running the meatiest tire I can on the rear.
    jetas likes this.
  9. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Pics of wheels mounted. The plan is to drop the front another 1”+ until it just clears. Pretty sure I can hand pull the fenders with a little heat. I’m assuming I’ll have to cut my front bump stops off completely?
    Perkolator and Erwin Merida like this.
  10. jetas
    Cut the bumpstops and remove the brackets.
  11. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Getting a little close there to curb rashing your brand new wheel!
    Ivey likes this.
  12. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Still needs to be lowered in the front.
  13. jetas
    Guna run those balloons out back or they getting smaller tires too?
  14. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Big ass balloons until I get tired of it. I’ll see how it all looks once the front fits better.
    jetas likes this.
  15. Justin Danger
    Bay Area Peninsula
    Funny, i'm in the oposite court. The front wouldn't look emaciated and need much of a drop if it was like the rear.
  16. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Yeah the tire is way too short. I bought some cheap ass fender flares to play with but I may just return the two I didn’t mount and get taller tires for the front. I’m gonna mess around for a bit before I cut anything.
  17. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Drives really nice though FYI. I always had to fight it around corners and now it just turns.
  18. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    That's because there's no sidewall to flex anymore! Lol lo_pro fx! I'd get used tires till you find the exact one you looking for.. can get away with $20-$30 a tire in some areas. Nd keep the flares, you might use them later
    Ivey likes this.
