What's the trick to forcing the fuel pump to run?
Discussion in 'Engine/Drivetrain' started by Perkolator, Mar 16, 2023.
  1. fred heath
    fred heath Addict
    Raleigh, NC
    water temperature sender should be yellow with green stripe. Easy way to check that is with the ignition switch “on” touch the bare wire to a ground. The water temp gage in the instrument cluster should “peg” all the way to “hot”.
    jetas likes this.
