What wheels/tires combo for retro look?
Discussion in 'Wheels/Tires' started by Manuel Rendon, Jan 25, 2023.
Best retro-looking wheel/tire combo?
  1. BFG RT 265/60R15
    0 vote(s)
    0.0%
  2. BFG RT 245/60R15
    1 vote(s)
    100.0%
  1. Manuel Rendon
    Manuel Rendon Newbie
    Dear all, I have a 1984 pickup and I was looking to change my wheels and tires to resemble more of a retro look. I’m thinking a BFG Radial tire with American racing Outlaw II, however I’m not sure what combination would be the most wider/positive offset so that it stays as flush as possible. I was thinking 265/60r 15 with +25offset 15rims 7 in the back and 225 in the front. What do you think? Here’s my truck, I’m painting it black.
  2. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    How did you come up with your choice of tire sizes?
    15x7, +25mm offset should tuck nicely under the rear fenders... with 215/60-15 tires. I used to have 205/60-15 tires on 15x7, 0mm offset wheels and they poked out about one inch. So, +25mm wheels should be flush with 205 or 215 tires.
    I dunno if 265 tires will even fit on 7-inch wheels. 245 might be the max. Go to BFG's website and see what rim widths are recommended.
    The tire size closest to stock diameter would be 215/60-15.
    Finally, IIRC, 15x7 Outlaw 2 only come in 0mm offset...
  3. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    i've run those wheels on my 86, probably some pictures in my build thread 'Betsy'. And as I recall they were 0 offset on my 15x7s.
  4. jetas
    The 2 tire sizes you have on the poll are going to be way too tall. Unless you plan on lifting the truck. Stock size on these trucks is something like 195/75/14.
    a 245 will be somewhat square on a 9" rim, 225 is pretty square with a 8" rim. 205 is closer to a 7".
    what retro look are you going for exactly? Because the sizes you mentioned are something like a 70's muscle car with the back tooted up with air shocks and Yosemite Sam mudflaps
    *side note* Cooper Cobras have the raised white letters also if you're looking for a slightly less expensive tire than the BFG
