i have a stock yota im tryin lower the i needed help with doing i dony know wherre to start this is my first yota and i want it to make it look good
How much mechanical experience do you have? It can be pretty involved to do it the right way. Not necessarily expensive, but involved.
im pretty mechanicl what can i do to lower my truck cause everybody has one raised up and i jsutwant to do something a lil diffrent in my town
It really depends on how far down you want to go. if you just want a couple inches, thenk you can crank the torsion bars and use blocks in the rear. Another route is to buy drop spindles foe a later year truck and modify your lower control arm to fit the later ball joints. Belltech sells 3" drop leaf springs for around $150 Each. And post pics of that truck for us to enjoy.
Yes, dropping your truck by using lowering springs changes the distance between shock mount posts and will require a shorter shock.
Well I've run into more problems. Cross treaded the back shackle nut an can't even get the front out. Put in a cheap little ubolt to limp it home and the nut has pulled thru plate at the bottom of the shock. An from what I can tell are the rn34 parts are discontinued
Start a new thread for your truck and your issues. Itl be easier for people to go thru and respond. And you have to give a few more details for anyone to help
