What bore size on master cylinder should I use?
Discussion in 'Engine/Drivetrain' started by Rynosaur, Mar 14, 2019.
  1. Rynosaur
    Rynosaur Member
    71 hilux with the front disk conversion, Currently running a stock 90s mc. I believe it's a 9.5"/single. The brakes are scary and lock up during hard/fast braking. I'm assuming I need to go up on the bore size to reduce pressure. What are you running or what do you recomend?
  2. jetas
    Correct me if im wrong but doesnt going up in bore size increase pressure?
  3. fred heath
    fred heath Addict
    Raleigh, NC
    Your truck was never designed for front discs. What you need is a proportioning valve to allow different pressures to the front and rear brakes. Changing the m/c will not help in this case. Maybe find a later model parts truck and source the valve from there.
    Rynosaur likes this.
  4. Rynosaur
    Rynosaur Member
    Bigger bore = more flow/less pressure build up
    I think :lol:
  5. Rynosaur
    Rynosaur Member
    I will defently look into this thank you, it current has a proportioning valve, maybe just needs to be replaced
  6. jetas
    Id try replacing the MC. On my 89 the MC went bad and the tires were locking up all over the place
