uneven after lowering blocks
Discussion in 'Suspension/Chassis' started by 87pickup, Oct 25, 2013.
  1. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
  2. 87pickup
    87pickup Member
    ontario ca
    87 single cab short bed
    OK the the shield can be flipped upside down? Sry for my retardedness
  3. 87pickup
    87pickup Member
    ontario ca
    Oh OK i got it thanks
  4. 87pickup
    87pickup Member
    ontario ca
    Do I need that shield?
  5. 1lowSr5
    1lowSr5 Addict
    In the garage
    Leave the shield, put the bolts in from the bottom and flip the nuts connected to the metal upside down. It will all fit with out cutting anything. Look at that how to it will explain everything.
  6. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    The thing that looks like 2 nuts connected by a strip of metal, is just that and is needed.... to bolt the strut rod to the bottom of the control arm. It needs to be flipped over to clear the ball joint once its bolted to the top side of the control arm.
    If your talking about the thick steel tab, that is shaped kind of like a sheild and welded to the front of the control arm....you need that too. Thats a steering stop... so your wheel stops turning and you don't rub your tires all up into the fender wells on sharp turns.
  7. 87pickup
    87pickup Member
    ontario ca
    OK thanks
  8. 1lowSr5
    1lowSr5 Addict
    In the garage
    All I gotta say is if your unsure with how to do it don't do it. You can mess things up including yourself if things aren't installed back properly. Last thing you want is to lose a lower ballpoint while driving...
  9. 87pickup
    87pickup Member
    ontario ca
    OK I'm pretty sure u guys are gonna say otherwise but I was told when doing the bj flip the balljoint goes on top of the lower control arm but on my truck the turning stop shield.looking thing was welded on so me being me I grinded the effer off is that bad?
  10. 1lowSr5
    1lowSr5 Addict
    In the garage
    Don't cut it off flip the the bolts welded to the nuts over, it can stay! :brickknock:
  11. 87pickup
    87pickup Member
    ontario ca
    OK so everything is done and lowered and I don't have much wheel travel before I hit the top of the wheel well how can I get more space ? Or do I just cut out the inner fender? I have 17s and running 215/50r17
