after changing the oil pan gasket and the valve cover gasket , the engine is very under powered, it takes twice as much to get up to speed. what could it be?
did you refill it with oil? really if that's all you did should be no power loss... did you adjust the valves?
no i just simply replaced the gaskets and oil, it does run much better at idle but when you put it in any gear it is very underpowered
love your dually buy the way have a 78 double headlight model they are freakin long had mine parked next to a ford excursion and mine was longer
What's that throttle cable lookin like its not binding or folding on itself is it changing gaskets should have no effect n performance check all the little things removed for the procedure
