Under Construction '93 gets bagged...
Discussion in '1989-1995 Build-Up/Project Threads' started by Under Construction '93, Feb 22, 2011.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Nice pics with all the cop cars lol looks good man
  2. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Man hurry up already..... Want to see final product.
    I used to do the same thing to my niegbors before i got rid of my banshee. But i used to dust there houses out from the lot next door. Well done man
  3. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    Got a few fittings I was short today and got all the plumbing finished. I have 1 fitting that leaks no matter what I do :mad: As I expected the rear is way too fast as well so I need flow controlls on the up as well as the down. It hops on the up with 1 quick hit only on 150psi.
    Full lift front and rear
    And here's a vid of the back less than 150psi:looney:
    2011-05-16_14-13-47_273.mp4 video by pumpkinpirate13 - Photobucket
    Hopefully finish the exhaust and get the bed on this weekend... Hopefully...
    Mr.Mini_4.0 likes this.
  4. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    lookin good :waytogo:
  5. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    That setup looks clean. Now lets see the front working.
  6. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    LOL Go a page or two back... There's a vid for the front already...:rolleyes:
  7. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Thanks!
  8. Paulyoung88
    Paulyoung88 Member
    Las Vegas, NV
    94 Toyota Pickup
    Pretty sick bro. I've been driving my bagged yota for several years. You dont always have to drive with high psi.Cause it all depends on how you plan on using your truck. The more weight you put into the back of the bed the slower it will raise up. Also airing up to 150 psi will make it jump up quick cause that's a lot of psi. You dont really need a check valve or filter to slow it down. Just air up with smaller amounts of psi. I usually air it up to 80psi and I take off. On freeways I air up to 120 psi. Pretty much same set up as yours. Looks awesome bro. keep up the sick work
  9. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I usually have 170 in my tank but I try an ride low as possible but can't in the front til I cut my fenders out lol
  10. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    I didn't mean that was the amount of pressure in the bags... Thats with the tank pressure at 150psi and 1 quick hit of the switch up... It lifts to max on the first hit... I know it will slow a bit with the bed and shocks on, but I think it's still gonna be too fast. I have a 200psi switch as well but the valves are so quick I dont need that much pressure. It's funny because I bought all the stuff to be fast and now I,m trying to slow it down...:p
  11. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Sounds good. I wanna ride lowest possible as well... Compressors came with a 200psi switch but it's faster than I want even at 150 on the up valves. Once I get the bed and shocks on, I'll make all the final adjustments.
  12. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Ya mine pick up fast too even with 120psi but the lift doesn't bother me it's dropping hella fast that does. Once I get bodied I'll put a plug with a hole drilled in it for a slow down. What bags are those? They look like the new slam SS series?
  13. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    RE 6's and 7's
  14. Da_Roach
    NOVA
    Truck looks really nice in person. The welds are killer and is built for some hard dragging. Cant wait to see it w/a bed and cruising.
  15. Dgerfan55
    lake elsinore CA
    94 pickup
    Man this truck has come along way, Looks killer man. I wish some day i can do mine. Keep it up man
  16. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Thanks guys. Should'nt be too much longer now...
  17. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    *UPDATE*
    Got the bed roughly cut out today. And I gotta say I'm a little nervous about how flimsy it is... :shrug: Havent fitted it on the truck yet cause I didn't have any help for lifting that tuna can. Probably will brace it up a 'lil if its still flimsy when bolted up.
    Also got some of the exhaust modified for ground clearance as well. But after that ran into another problem... My old flowmaster muffler is too big now for the space I have to work with. So now I gotta spend more $$$ and get a shorty muffler or something... Looked for a cherry bomb at the local pepboys but they didnt have any small ones.I'll figure something out.
  18. Da_Roach
    NOVA
    Is always something isnt. The bed looks nice all cut out.
  19. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Thanks... And yea, It's always something. And the water pump. :mad:
  20. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    The bed is cut out like mine man. Alittle flimsy but works fine. Nothin wrong with some bracing either tho. The way I was gonna do it was run 1"x1" from each bed mount across but haven't got around to it
