Under Construction '93 gets bagged...
Discussion in '1989-1995 Build-Up/Project Threads' started by Under Construction '93, Feb 22, 2011.
  1. HEIGHTZ
    HEIGHTZ Member
    Kentwood, Mi
    93 4runner
    eliminates bump steer. Better suspension travel, strut rods are turrable.
  2. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    But that would be no bueno on a static street truck correct? (To remove it )
  3. HEIGHTZ
    HEIGHTZ Member
    Kentwood, Mi
    93 4runner
    as long as you re triangulate the lower arm with a tube/bushing/mount braket, it is ok to remove. I did it to my 63 buick as well.
  4. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    On my truck strut rod is all up in my way of th lower rad hose. But I'm managing that lol
  5. HEIGHTZ
    HEIGHTZ Member
    Kentwood, Mi
    93 4runner
    my old mazda was the same way lol Can buy a kit for $100 or so...I did my buick for $30 and will be doing my 4runner too. Unless I convince the boss to water jet some lowers for me.
  6. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    Who sells the kit? And thanks for the quick suspension lesson lol.
  7. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    it helps with camber issues for being so low also gives you a place to mount shocks.not to mention looks a lot cleaner better geometry.
  8. HEIGHTZ
    HEIGHTZ Member
    Kentwood, Mi
    93 4runner
    some guy I will not promote, good fabricator, but the wait is rediculous along with cusomer contact. :duh:
    ps...sorry for hijacking the your build thread buddy, proceed
  9. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Thread jacked yet again Batman...
  10. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Damn I've missed out on a lot of this build. The cando arms are great. On the lower balljoint you will need to either make a spacer or put washers under the nut so the cotter pin goes threw both the hole an nut. Learned this when my balljoints went out an almost lost the nut.
  11. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Yikes. Will def look into this. How bad was it doing the lowers on yours? You have truouble getting the bushings/ sleeves out? Bout to tackle that today hopefully.
  12. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    The bushing was a pita to get out. I took a sawzall an cut it an just beat it out. That took the longest but other then tht it was pretty straight forward. Ya I think i stacked like 2-3 washers on the lower balljoint. I called Steve and talked to him when it happened to me that's what he said to do. When I take everything apart ill make a spacer instead of the washers. Make sure u get the part numbers for the ball joints incase u need to get new ones haha
  13. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    haha sorry about that! :evil:
  14. john9280
    john9280 Member
    florida
    1990 toyota truck
    anymore progress on the clutch master cylinder would like to see some pics about to relocate mine soon
  15. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Will have more pics this week. Been on vacation for the past 3 days. Back to work on Tuesday and get the ball rollin' again.:cool:
  16. pivins45
    pivins45 Member
    Wilmington, North Carolina
    94 Pickup Ext Cab
    Haven't seen this build in a while.. Those wheels are wicked man. Looks awesome!
  17. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Thanks bro.
  18. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    Been working on flipping the clutch master throughout the week. Taking alot of pics for a future detailed writeup... Also going to do a detailed writeup for the Z as well. Here are a few progress pics...
    Should have the pedal assembly finished up this week. Here are a few of controll arm install progress. Had to be a reciprocating saw for the Z project... Removal of the LCA bushings / sleeves was the worst.
    Stay tuned for updates as well as the detailed writeups in the tech section...
  19. 93_Toy_Mini
    93_Toy_Mini Addict
    Gardnerville, NV
    93 Reg Cab Pickup
    Awesome! It would be nice to see that before I start mine next month.
  20. Under Construction '93
    Riverside,Ca
    1993 Std Pickup
    *updates*
    Z is welded in place, now need to build plates. Anyone else have to cut alot off the gusset from can do in the last pic? Its almost 5/8 off.
