Trekker build
Discussion in '1976-1983 Build-Up/Project Threads' started by slacker, Feb 25, 2009.
  1. slacker
    slacker Addict
    Penticton BC , Canada
    84-7m-GTE custom
    front engine harness is now done as well :)
    also started on the vent windows..
    i'm tinting the windows , so while I was at it , I figured I might as well clean up the frames (there was a little rust)
    so all sandblasted , and ready for some epoxy
  2. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    is that little fuse/relay box all that is required to run the engine? (besides ecu and underdash fuses..)
    i'm just tryin to figure out how big of a box i'll have to add in my hilux when i get the motor wired.
    truck is coming along awesome!! :waytogo:
  3. slacker
    slacker Addict
    84-7m-GTE custom
    thats it .. but you have to remember , it does take the smaller "waffer" fuses .. but yeah ... thats the one
  4. slacker
    slacker Addict
    84-7m-GTE custom
    ok .. so cab back off.. and now almost ready for some color :)
    just some welding and prep. first
  5. slacker
    slacker Addict
    84-7m-GTE custom
    continueing on .. and excited for it's coat of color ...
    I welded up a bunch of unwanted holes on the firewall and got all the new nuts installed to make the pieces "boltable" .
    also working on the tranny tunnel ..
    got it cut and ground
    also started to attach some of the "hold down studs" for the emergance brake cable .. still have to do the rear heater line hold downs .. I used these pieces , and just drilled holes to plug weld them in place ..
    got lots of the welding I wanted to do .. but I still have a bit more ..
  6. slacker
    slacker Addict
    84-7m-GTE custom
    got my tank filled today .. and continued on ..
    got lots done .. but was slowed on finding 11x1.25 mm nuts for the seat belts .. crap , I forgot all about it !!
    I ended up spendin 1/2 the day looking for these stupid little nuts , finally I went to the wrecker and "knocked" some off with a hammer and chistle ..
    so anyway .. made some backing plates for the seatbelt and seattrack bolt down nuts ..
    and got them welded ...
    just about ready to seal up the underside and give it some BLACK ...
  7. slacker
    slacker Addict
    84-7m-GTE custom
    still prepping for paint ..
    got the firewall all cleaned up .. found a wee bit of rust , but soon got that dealt with
    cleaning up the firewall
    all wire wheeled , and cleaned
    scuffed and zinc'd
    also got the underside scuffed and zinc'd
    the topside and bottom side wil be "sealed" in the paint booth ...
    ant last but not least .. I POR-15'd the inside of the rockers , cab corners , and cowl ... I was able to scuff the rockers and cab corners when I had them apart .. the cowl I was not able to ..
    I dont know how well the POR will work in the cowl , but I figured It would be better then nothing
    and YES .... tomorrow it goes to paint the inners :)
  8. StupidSheet
    StupidSheet Addict
    Canada
    Wow lot's of progress! Can't wait to see the paint!
  9. slacker
    slacker Addict
    84-7m-GTE custom
    buttoned up the Power steering lines today .. but found my return line just a few inches to short .. I'll have to replace that !!
    originally , there was /is a bracket for the Main power wire for the starter , housed in a white plastic surround , just around the face of the oil pan ... I wanted to keep it , so I made up a new bracket for the wire casing to "clip" to .. as well as a support for the P/steering line
  10. slacker
    slacker Addict
    84-7m-GTE custom
    pic I forgot to post ...
    anyway , the last thing i had to do before the inner paint .. was the new windshield washer nozzles ..
    now located on the hood ..
    holes cut
    and nozzles installed
    I also finished the underside , I made the holes for 3 washer hose clips ..
    and thats it for now ... deliverd for some color
  11. slacker
    slacker Addict
    84-7m-GTE custom
    not much to add ..
    couple of little things .. + got the P/S return line replaced ..
  12. slacker
    slacker Addict
    84-7m-GTE custom
    so a little bit today ... now that the cab is in the paint shop .. I needed to paint some pieces myself..
    satin black
  13. slacker
    slacker Addict
    84-7m-GTE custom
    and the dash bezzles :)
    same satin black
  14. slacker
    slacker Addict
    84-7m-GTE custom
    checking in on the paint today .. and it will be " hi-build" primered tomorrow :)
  15. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    would this be considered as a trekker its on craigslist.
    1986 TOYOTA PICKUP
    Runes excellent
    5 speed stick
    FITS 5 PEOPLE
    171 Miles
    For more info. Please Call 951-663-6368 HABLO ESPAÑOL
  16. slacker
    slacker Addict
    84-7m-GTE custom
    NO .. looks like a modified pickup .. with w 4runner topper ...
    trekkers are SPECIFIC .. 81-83's ONLY .. (only 1 verified/suspected /80 )
    http://www.toyotatrekker.com
  17. slacker
    slacker Addict
    84-7m-GTE custom
    so a little bit more today ...
    got the alignment done , and locked down .. steering damper is also now attached ..
    replaced the spark plugs with a heat range lower and platenum tipped ($80.00 bucks) and also a lower temp 170* gates # 33867 thermo .
    front drive shaft is now in the works ..
    some cleaning and POR15 in the works ...
    on the front part of the drvshaft .. under the u-joint , there is a plug ... I have misplaced the size /part #
    anyone know it ?
  18. slacker
    slacker Addict
    84-7m-GTE custom
    got everything back together today . I checked some of the aftermarket stores today, for the dish style frost plug and had no luck , most wern't open today because it was a holiday , so I ended up taking the plug out of an old shaft I had from another truck that I parted out ... I "miked" it .. and was 34.25MM .. if anyone is ever interested..
    anyway .. I install the plug , and cleaned and washed and prepped for the POR15 coating ...
    Chassis is now complete .. (once I bolt on the front shaft) ... only thing left to do is the Gear oil ...
    everything is done :) and ready for the cab
  19. smartmonkey
    smartmonkey Veteran
    Australia
    v320, 620, 720KC, RN46, LN46, YN65 & B2200
    Keep up the good work :waytogo:
  20. slacker
    slacker Addict
    84-7m-GTE custom
    ALL gear oils changed today ...
    also picked up the locks .. ALL were re-key'd to match ..
    i'm ready for the cab !!
