Trekker build
Discussion in '1976-1983 Build-Up/Project Threads' started by slacker, Feb 25, 2009.
  1. slacker
    slacker Addict
    Penticton BC , Canada
    84-7m-GTE custom
    so continueing on with body work and finishing ..
    I took apart the rear seats and readied them for new covers .. and "buttoned" up the modifications to the supports and levers .
    cut and welded .. and sandblasted , and zinc'd .. ready for some color
    also tore apart the front bumper that took me a year to find..
    got the supports and underside of the filler panel sandblasted and cleaned up .. ready for some POR-15 to seal .
    and done
    also cleaned up the inside of the bumper , and scuffed the chrome , and zinc'd
    and polished and buffed , and waxed the front ...
    almost ready to put it back together , just need some color on the topside of the filler :)
  2. StupidSheet
    StupidSheet Addict
    Canada
    Lookin sweet Slacker!!! Keep it up man, it's moving along nicely!
  3. jctoy29
    jctoy29 Addict
    surprise,az
    looks like new. nice!:)
  4. slacker
    slacker Addict
    84-7m-GTE custom
    new valance mould done today . waxed , and ready for a new piece tomorrow :) .. also .. bought my new sterio today
  5. slacker
    slacker Addict
    84-7m-GTE custom
    popped the new valance out today ..
    I like it ...
    also POR-15's the fender/valance mounts , as well as a bunch of other stuff .. but here's those pieces
    Teardown is continueing
    time to remove the wire harness
  6. slacker
    slacker Addict
    84-7m-GTE custom
    started working on the doors and inner trim panels .. got the inner of the doors cleaned up , and just about ready to prime .. also started on the trim panel
    started with a flat sheet of fiberglass
    marked it and trimed it to fit
    I was going to have it 2 seperate pieces , like the stock panel , but my "mid speakers are to big :) ... there is a small "step" in the door panel anyway .. so cutting it and re glassing it will achieve a perfect fit with NO rattles .
    starting the "mock up" for speaker location :)
  7. slacker
    slacker Addict
    84-7m-GTE custom
    so .. waiting in the shop today (my day off) for a customer to show up for some pieces .. I decided to clean up the headlamp buckets and mounts ..
    dissmantled them .. and did some sandblasting
    and all the regular cleaning .. and such .. and some POR-15 on these as well .. also while I was at it , I polished up the headlamp rings and hardware :)
  8. slacker
    slacker Addict
    84-7m-GTE custom
    not much to add ...
    got the headlamp bucket and pots back together
    and the power went out ..
    ended my day early
  9. slacker
    slacker Addict
    84-7m-GTE custom
    got a little work done on the door panels the last few days .. building the speaker enclosures has been the most time consuming , but should pay off in the long run .
    Instead if just cutting a hold in the door and mounting the speaker on top , I wanted to "enclose" the speaker in it own "pod" so the sound coming out of it is just that much better .. so I was thinking on how to do this .. building custom moulds would take to long .. and i'm really wanting to press on !!!!
    so I decided to start looking for a mould already build which I could utalize .. started pulling bowls out of the cupbords and measureing for size , looking at all kinds of things I could use , even went to wallmart and searched for aplicapble forms . I ended up going to the dollar store , and finding a perfect size plastic dog dish for $1.50 and a smaller cat dish for $1.25 .
    started making my pieces ..
    so I have 4 mids and tweeters going in .. 2 front 2 rear .
    I needed 6 bigger pieces , and 4 smaller pieces ..
    so after I figure the speaker placement .. started to fit it all together .. cut the door metal to fit the "pods" and glassed the rear portion into place
    cut down and prepped the new set of moulded pieces to fit the speakers
    and all mocked up
    ready for some foam and leather to finish !!!
    should rock :)
  10. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    wow thats awesome man, wish i could do fiberglass like u can..
  11. slacker
    slacker Addict
    84-7m-GTE custom
    pretty easy ...
    I'm now in contract to do a "do it yourself" book .. should be really helpfull
  12. trap
    trap Addict
    orange county ca
    92 pickup
    Its quite interesting to see how someone who obviously does lots of fiberglass, but not necessarily stereo work build a door panel.
    I like the speaker baffles, but the majority of car audio speakers are not designed to be in a sealed enclosure. It doesn't mean they absolutely won't sound good, but it will significantly change the way that speaker sounds. In my experience they are usually harder to tune, and give you a "snappier" mid bass.
  13. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
    Tell me you're gonna sell them to all us 79-83 guys with beat up door panels! Looks like a killer upgrade. I would vent the speakers somewhere too, like trap said. Fully enclosed can make them sound boomy.
  14. trap
    trap Addict
    orange county ca
    92 pickup
    I was thinking venting the bottom personally so they still served a funtional purpose as a weather guard. I would try them sealed, and pull out the body saw if they don't sound right.
  15. slacker
    slacker Addict
    84-7m-GTE custom
    dude .. your right .. I'm NO sterio guy :D , I know nothing about doing it right .
    this is why I asked a professional before I did anything ..
    because of the size of the airspace behind the speaker .. I shoud be good with the sound + weatherproofed is always good
  16. slacker
    slacker Addict
    84-7m-GTE custom
    did a little clean up on the wiper motor at lunch time today ..
    pulled it apart and cleaned everything up
    didnt have to paint anything .. except the alum. housing.. and the assy. screws.
    acid diped and then bead blasted .. and then clearcoated
    all back together ..
  17. slacker
    slacker Addict
    84-7m-GTE custom
    little work on it today
    I was able to start stripping everything out of the cab .. prepping to remove the cab for inner paint ..
    Wire harness is also now out .. so I can finish with saldering the joints and loom/tape .
    and a little look see of the pieces stripped from the truck
  18. slacker
    slacker Addict
    84-7m-GTE custom
    so the rear tub has now been removed , so I can now finish the glass work .
    Tub support also removed , and I was able to finish the welding on it some POR 15 and it'll be done and ready for reinstall
    engine bay is almost stripped ..
    cab is almost ready to come off :)
  19. slacker
    slacker Addict
    84-7m-GTE custom
    so friday night TV .. no good shows and board so back at er'
    a pic of the tub .. ready for the final cut outs and glassing..
    also POR'd the rear frame support and other goodies :)
    and started on the wire harness ..
  20. slacker
    slacker Addict
    84-7m-GTE custom
    some work on the weekend I neglected to post ..
    wire harness is comming along :)
    also today , I got the tub trimmed up , and basically finished the topside ..
