Trekker build
Discussion in '1976-1983 Build-Up/Project Threads' started by slacker, Feb 25, 2009.
  1. slacker
    slacker Addict
    Penticton BC , Canada
    84-7m-GTE custom
    ok .. so , I took yesterday off sunday the 13th , as it was my B-day .. and " I wasnt aloud to go to work :) "
    so today .. I popped out the new pieces ..
    I cant wait to get them on !!!!!
    consol is in the booth having the mold made :)
  2. StupidSheet
    StupidSheet Addict
    Canada
    Happy Bday!!! Everything looks great as usual. Love the progress!
  3. slacker
    slacker Addict
    84-7m-GTE custom
    Thanks bud ...
    so just to let every one know ..
    I "peeled" out the "plug" for the console .. I now have a "basic" mold :)
    I still have to "wet" sand ... and wax and polish .. but if all goes well , I should have a NEW piece by the weekend
  4. slacker
    slacker Addict
    84-7m-GTE custom
    so pulled the piece today ..
    trimmed it up , and "roughly" did the cutouts to fit it ...
    fits like a glove :)
    still have to put the guages , cupholders and such in .. but this will give you an idea
  5. Megaglow_Z
    Megaglow_Z Addict
    Benton la
    81 long-bed goodness
    looks GOOD!!!
    When are you going to sell these, and how much???
  6. slacker
    slacker Addict
    84-7m-GTE custom
    I'm not ...
    .. this is a 1 OFF ..
    for my build only
    I destoyed the mold ....
  7. slacker
    slacker Addict
    84-7m-GTE custom
    sorry for the slow progress ...
    but today I have a wee bit of an update .
    started the drivers door panel , I have to re-pin the hinges , so I will be sure to post that as well .. (hopefully this weekend) but for now , this will have to do
    started with removing the door and hinges
    Next .. with the grinder "clipped" the edges
    and off comes the skin .. there is a few spot welds , expecially for the vent window supports .. but easlily dealt with ..
    New skin goes on .. and time to make it stick !!
    I didnt have a mini rasp, have to go buy one .. so I called er' a day ..
  8. slacker
    slacker Addict
    84-7m-GTE custom
    got the flanges cleaned up today .. and got the POR15 on them
    also "cleaned" up the inside , and got it POR15'd
    trimmed up the holes for the handle and lock
    and installed and ready to "bond"
  9. StupidSheet
    StupidSheet Addict
    Canada
    Aaaaahhhhhhh I love see progress on this build!!!
  10. Megaglow_Z
    Megaglow_Z Addict
    Benton la
    What changed?
  11. slacker
    slacker Addict
    84-7m-GTE custom
    in my haste , I fucd up ... I built the flange in the wrong position .. I order to get the part out , I had to break the mould . I saved the part , but ruened the mould .. :cry:
  12. slacker
    slacker Addict
    84-7m-GTE custom
    ok continueing on ... In order to "attach" the fiber skin .. you need to scuff the panel , where it will contact the metal shell , for as the say in the industry "tooth" , meaning .. something for the epoxy to stick to
    fiber panel
    metal shell , back to bare steel .
    The epoxy I use in my shop is 3M panel bonder .. it's expencive , but if done propperly , it will never come apart , and they guarentee it !!
    so now .. epoxied .. and clamped .. just has to cure ..
  13. slacker
    slacker Addict
    84-7m-GTE custom
    so now the door is "curing " ...... time to address the hinges ..
    lots of play , so time for some new hinge pins .
    had the hinges sitting in a pot of deluted hydrofloic acid over night
    so it make sandblasting a little easier and heres the works ..
    had to cut the pin , and punch it out
    next , I had to drill the old hinges to fit the new bushings
    both sides have to be done because , the pin is a little larger . File the " burrs " and install the new bushings .. The pin also has to be trimmed , because it was to long .
    I "plug" welded the bottom of the hinge , for safty .. and a little primer ... DONE
    just have to wait for the epoxy to cure .. and I can mount the door :)
  14. 77yoter
    77yoter Veteran
    seattle
    77 sr5 shortbed, 81 shortbed, 90 4x4
    i have to say you are doing some beautiful work like it alot:love:
    i wish i could afford one of your kits
  15. slacker
    slacker Addict
    84-7m-GTE custom
    thanks .. start saving :waytogo:
  16. slacker
    slacker Addict
    84-7m-GTE custom
    all excited , I went in this morn. to get the door mounted .. removed all the clamps , and connected up the door handle , bolted on the hinges .. and got the door back on
    Marked the position of the mirror , drilled and "nutcerted"
    and put the mirror back on
    Very happy with the way it turned out .. when I trim the fiberglass panels , I always trim them LARGE .. so there is enough panel to make my own panel gaps . it's always easier to remove material , then to add it . So when I do the "final" body work , I will be able to sand down the door edges , to make perfect panel gaps
  17. slacker
    slacker Addict
    84-7m-GTE custom
    couple of things to add ...
    got the center console drilled mounted , and also removed the dash , and 3 guages , and mounted them in the upper console .. also sent the r door mirror away for plastic chrome
    I'll also be re-working the dash bezzle again .. hopefully for the last time
  18. slacker
    slacker Addict
    84-7m-GTE custom
    so as mentioned .. center console is now mounted .. got the gauges in .. also started to re-do the dash again !!! I think this dash has been the hardest thing of all .. you look at it all the time , and I'm trying to get the "best" aesthetic value I can ..
    I hope this is the last time !!!
  19. slacker
    slacker Addict
    84-7m-GTE custom
    so .. done , well "rough in" anyway :)
    I'm very pleased , and will be able to look at it for a long time .
    I went with the /83 ashtrey , and the /99 lighted , cig lighter .
  20. StupidSheet
    StupidSheet Addict
    Canada
    Looks factory!!! Nice job!
