tranny sound
Discussion in 'Engine/Drivetrain' started by brovender, Sep 22, 2012.
  1. brovender
    brovender Enthusiast
    Upstate SC
    1973 Hilux RN27
    i definitely will man. thanks alot for the help with this issue.
  2. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    Good luck, take pics and show us what ya find :D
  3. brovender
    Upstate SC
    1973 Hilux RN27
    for sure man! i'm just hoping there's no surprises haha.
  4. brovender
    Upstate SC
    1973 Hilux RN27
    so upon removal of the transmission i'm missing the two clips that hold the fork onto the bearing... uhhhhh any idea what they look like and anything i can replace them with?
  5. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Dealer ship might have them best pics I could find might find them witha thro out bearing kit at a parts store
  6. brovender
    Upstate SC
    1973 Hilux RN27
    my fork/hub have a little hole in them which led me to believe the clip you posted wasn't the right part. plus my fork is a different style. i ended up finding the parts from a dealer in florida... they're two measley little u-shaped clips that hold it in place. they apparently were used on landcruisers too? i hope i'm right.
  7. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Yea I've seen those Toyota changed small things thru the years clips throw out bearings with ears on them and some with out mounting ears .just make sure the bearing is secure operate the fork and hope that fixes your noise ..
  8. brovender
    Upstate SC
    1973 Hilux RN27
    i'm hoping so too. it's been such a pain sharing a vehicle with my girl since my truck's been down. hey, any advice on getting the throwout bearing collar out?
  9. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    You talking about the thro out bearing . Bearing hub that sits inside the the thro out bearing
    May have to press it out if u don't have a press I'd run up to a mechanic shop see if they can press it out for you ..or maybe come up with a large socket and a vice to clamp the bearing < don't crush it hammer on the socket see if it pop out w d 40 it two
  10. brovender
    Upstate SC
    1973 Hilux RN27
    i meant the bearing hub :D
    do i have to use the same method to get that out? mine's pretty snug. no amount of prying seems to be dislodging it.
  11. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Prying it out might get messy a press is a safer method does your thro out bearing look like the one on the right in the pic of so u need to remove that middle peace as you no . A large socket that fits in there same diameter as the hub then place in a vice and see if u can nock it out .if not have a shop press it for u so u don't damage the mating surfaces
  12. brovender
    Upstate SC
    1973 Hilux RN27
    yeah it's the two piece design. if the hub isn't damaged can i just replace the bearing? everything else looks fine.
  13. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Yea u can do that if maybe try letting it soak in some pb blaster or wd 40 overnight
  14. brovender
    Upstate SC
    1973 Hilux RN27
    i got everything put back in and i'm still having the same issue. :confused:
    my master cylinder's new, good throwout bearing, new clips to hold it in place.
    only part that's left stock is the slave cylinder... could this be the cause of my issue? (could it not be disengaging all the way???)
    i'm so bummed. :(
  15. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Didn't. U say yours was leaking and your getting a new one ..I no it's a bummer man I'd replace just to replace it cause I temper u sayin it was leaking wouldn't hurt ...have you though about trams replacement or a possible rebuild I no that's a mouthful but this issue maybe internal
  16. brovender
    Upstate SC
    1973 Hilux RN27
    i haven't noticed any leaking from the slave cylinder itself, i was having leaking from the master but i've got a new one on the truck. i removed the slave and it looks like it's seen better days. there's lots of built up crap inside of it and on the piston. only reason why i haven't considered a rebuild is because of the condition of the transmission... it shifts great, isn't leaking, and doesn't make any strange noises.
    it sounds like the clutch just isn't fully disengaging though. i haven't lost any gears and i can still shift, i just have to keep the clutch engaged at all times. :shrug:
    on a better note, i found a neighbor who has a '78 hilux!
  17. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Replace that slave cylinder and see what u get . Bleed it real good it may be faulty on the inside its a cheap part so it couldn't hurt to try
  18. brovender
    Upstate SC
    1973 Hilux RN27
    i'll give it a try... yay new rockauto magnets
  19. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Ha yea never have enough magnets ....my buddie just got a slave cylinder at the parts store sat for 12 dollars so if u have a local store and there in stock try that if u don't wanna wait on the mail
  20. brovender
    Upstate SC
    1973 Hilux RN27
    do you know which parts store?
