Trailer harness
Discussion in 'Interior/Electronics' started by eurofreak2002, Feb 10, 2011.
  1. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Does anyone know if the 2wd came pre-wired for a trailer harness connection. I bought a LED light bar for my tail lights at a real good deal problem is it came with the 4 pin connector. I just need to know if they might have prewired the trucks for such and the wires are tucked up in the frame somewhere maybe??? If not guess I'll make my own harness.
  2. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    I dont think they do. It would be there if u had one. Bummer because i just threw one away...You need one that converts the separate turn signals into the brake lights. At least for a 4-pin trailer harness anyway... Good luck.
  3. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    ^ correct. you need the 5 wire to 4 wire converter box to have a 4 wire trailer plug. our trucks don't combine the brake and turn lights. Most places that sell hitch/trailer parts should have it available. should run 25-30 bucks. I've seen them at autozone and walmart in that range. some places will want $50+...go elsewhere.
