traded my drift car for a new project...
Discussion in '1976-1983 Build-Up/Project Threads' started by lucky7, Sep 29, 2011.
  1. lucky7
    lucky7 Member
    portland, OR
    77' hilux
    Ok I think the next plan is to cut the bed smaller... Or just chop out like 6"inches of frame or something hahaha I just need it to be not as long as a damn cressida
  2. Ry M
    Ry M Newbie
    Any pictures of your hydro brake setup?
  3. lucky7
    lucky7 Member
    portland, OR
    77' hilux
    I have to finish mounting it all up and I'll get pics(honda slave cylinder- went to the parts store and got universal 4' brake hardlines- prop. Valve goes to slave, other line off slave goes to T-line off the diff.. Make a bracket, make a handle and done)
  4. ghettoyde
    ghettoyde Enthusiast
    Nampa Idaho
    What size wheels and tires are those on the front?
  5. lucky7
    lucky7 Member
    portland, OR
    77' hilux
    Factory chevy pickup rims- believe they were 15x7 close to a 0 offset
    Tires were 195 60 15 but have since changed to 195 65's
  6. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Gm never used the 5 x 4.5" bolt pattern those wheels look to be generic wagon wheels.
    I'm running 205/60's on the front and 195/60's on the back and everything clears well with 15 x 7" wheels with about a -50 or so offset. Did you flare the fenders? It looks like it but its hard to tell in the pics.
  7. lucky7
    lucky7 Member
    portland, OR
    77' hilux
    might have been a ford pickup- or dodge not sure..
    and nope no flare just a slight "newspaper" roll thats it, you have negative 50's?!?!?! whats that like 10 inches of dish ??
  8. White Trash
    Eastern WA
    No they are factory early 80's jeep cherokee wheels. 15 x 7 with around 4" backspace. I do have some super light 3.5" backspaced 15 x 8's but I'm too low to make them work without major work.
    One of these days I'll have to look up how the metric backspacing is figured. I ASSume its in millimeters I just don't care enough to learn. :lol:
    Small Ford truck, 2x dodge dakotas, and early to mid 80's half ton dodge all used the same bolt pattern. I have had several sets of those white spokes. Pretty standard to use them for snow tires around here.
