Toyota Well-Done
Discussion in 'Pre-1975 Build-Up/Project Threads' started by 74Hiluxproject, May 11, 2012.
  1. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    That may be an option.
    If it will help I have a 5m bellhousing including flywheel, low mileage clutch, clutch fork, slave cylinder etc so you can bolt a W series trans to your engine.
  2. 74Hiluxproject
    74Hiluxproject Enthusiast
    Olympia WA
    1974 Toyota Supra Truck
    yea ill have to figure something out for a tranny, unless i can come across a r154 that i wouldnt mine paying for, i may have to go a different way, we will see though ill keep that in mind
  3. 74Hiluxproject
    Olympia WA
    sig test
    ** works, im painting that on my tailgate!
  4. AIRICK
    AIRICK Enthusiast
    Northern KY/ Cincinnati Area
    83 Standard Pickup
    Cool project! Make sure you're well read on the 7M's...they can be tricky. Supramania.com has some good info if you have any questions on it. Good luck
  5. 74Hiluxproject
    Olympia WA
    Thanks
  6. 74Hiluxproject
    Olympia WA
    Back from the family trip, tore out the interior and dash of the supra
    Wireing harness
    A/c and air unit under dash
    Dash and dash support
    seats and headliner
    my co-captain on the project
  7. 74Hiluxproject
    Olympia WA
    So ive been measuring over and over... and over, and my measurements are usually right 7/10 times, so i measure about 20 times to make sure.
    The plan is to cut out the firewall and the transmission/ drivetrain tunnel of the supra, same with the hilux, and swap it
    This may or may not work, but ive seen crazier done. Ill cut the supra first and try to get it as close to a "perfect" fit before i cut up my hilux.. just a plan for now but i think it would be best since i will have to make the drive train tunnel bigger, and if i could get everything to bolt up where its going to be it would be easier then making all my own... although i think i could do it, it would be easier lol
  8. 74Hiluxproject
    Olympia WA
    Just went and brought my frame home now that i have the subframes i can get an idear of what needs to be done to make them fit
    makes me happy lol
  9. 74Hiluxproject
    Olympia WA
    rear subframe pulled and getting moved into position! going to cut off the leaf springs n such, updates tomorrow
  10. 74Hiluxproject
    Olympia WA
    I lied, no update today, got called into work as i was attempting to pull off the leaf springs and rear axle :(
  11. 74Hiluxproject
    Olympia WA
    Im actually getting rid of a bunch of stuff now, i dont know if anyone is local but i got a rear axle, steering clumn with working ignition and key, upper and lower a arms for front, i have the 80 disc brakes for the front drum to disc swap the little heater motor guy under the dash, pretty good dash pad, guage cluster etc... pictures on on the first couple pages if anyone is interested lmk
  12. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    Damn I want the breaks but shipping would be a bitch I bet..Whats needed for the swap over?
  13. 74Hiluxproject
    Olympia WA
    the ones i have are discs off a 80, just pop off the drums and put left on the right, and right on the left, comes with everything but calipers and the flexible brake lines
  14. White Trash
    Eastern WA
    So what do you want for the rear axle? :D
  15. 74Hiluxproject
    Olympia WA
    cheap, like 25$ but no tires
    **its the stock hilux rear axle, not the rear subframe from a supra, since you were wanting the front subframe
    *** woo for enthusiast lol
  16. White Trash
    Eastern WA
    Sold! I can afford them parts!
  17. 74Hiluxproject
    Olympia WA
    Got a little bit done today before work, got the rear axle and leaf springs off, i think at this point its ready to move to the shop so i can start fitting the frame to the sub frames, lmk what you think
  18. 74Hiluxproject
    Olympia WA
    Got the firewall and drive train tunnel out of the supra to retro fit into the hilux
    sorry if the pictures are a little dark, was running out of day light
  19. 74Hiluxproject
    Olympia WA
    Supra Truck
    Update:
    74 hilux frame = hacked up
    88 Supra rear subframe = welded onto hacked up hilux frame
    Got her on two legs now! Seeing this thing come together is really awesome i hope it turns out like i want it to, i have so many good ideas, just hoping to see all of them come together and work.
    Here some pictures, my brother in law came up from Arizona for a little family visit, talked him into helping me out.... ok i didnt really have to talk him into it, he wanted to work on it as badly as i do lol
    picture story go!
  20. 74Hiluxproject
    Olympia WA
    Supra truck
    Did some work on the frame again, once i got the front subframe on my frame came out super un level, because the front subframe even at full slack is taller then the rear, so i cut the back off and blocked it about 4 inches or so to bring the frame up level, so im sitting about 5 inches off the ground from the bottom of my frame now.
    Before
    After
    Im going to clean it up a lot better after i get everything position how i want it, everything is just tacked enough to hold it so i can get it out of the shop.
    Under the front sub
    Rolling on 4 wheels now
