Today on my truck I.....
Discussion in 'Off Topic' started by nvrenufedge, Jun 3, 2010.
  1. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Finished up the new front cross brace
    you can see in this photo the stock cross brace trimmed down & in the new position. The area right under it was all removed
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    this is the part made from 1'x 1 1/2'' .025 wall tube & boxed in with metal sleeves inside the holes
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    In place , gained another 1'' of drop @ the front!:cool:
  4. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    10K HIDs? just an FYI, your not going to be able to see a damn thing with that color of light.
  5. IronNam
    ^^ Yup, majority of 10k isn't even visible light.
  6. not forgotten
    not forgotten Addict
    Washington
    82 SR5 L/B
    My HID Kit is 4300K white.
    Today I got my Lokar interior door handle problem fixed, works very smooth now. The problem lied in the adjustment screw which tightens the cable up to 1/2".
  7. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Yup same here 4300k .10k bring a flashlight
  8. burquescraper
    burquescraper Member
    Charleston sc
    87 xcab 91 rx7 totaled:(
    true but for 50 bucks for the conversion they'll still be better then the old s#$tty halogen blocks that are on there now and i can always get new bulbs later
  9. Robert m
    Robert m Addict
    Apple Valley, Ca
    no, they wont be better. get new bulbs now
    HID Kits, BMW Aftermarket Bumpers & Lighting, DEPO - DDM Tuning
    and for less then $50 you could have gotten a kit from DDM and gotten the correct color...
    http://www.ddmtuning.com/Products/DDM-HID-Kit-Slim-Ballast-35W-or-55W
    http://www.ddmtuning.com/Products/Apexcone-Raptor-HID-Kit
  10. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    The DDM Tuning is the one I got,55 watts, high /low beams, believe it is the 6000.
    Is great!!:cool:
  11. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    But its a bigger number it simply HAS to be better! :ROFL:
    I was inspired by a thread from a couple weeks ago to finally put the jaz filtered catch can to use so my engine stays clean.
    No more oil residue on the valvecover for me! :D
  12. TDS909
    TDS909 Veteran
    ONTARIO
    1992 st cab
    I replace rear shock's, Then wrote out my plan's for my truck:eyecrazy:
  13. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    added an Alarm and power door locks. kicks ass having key-less entry FTW
  14. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    RX-8 18-8's FTMFW.
    surprisingly the ride is better than the 17x7 IS300 rims I had before.
    looks hot!
  15. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Not on my truck, but spent the day tubing the rear of a Nissan
  16. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Also removed all the shrouding around the filler neck & relocated it with a bracket
    the gas door is shaved
  17. Yotaforce
    Yotaforce Enthusiast
    Sacramento, CA
    94 xcab
    New bumps in as of 5 minutes ago. I'm hoping low in two weeks or so (depending on shipping)
  18. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    removed and cleaned all 4 rims. they are supper clean now. also replaced a P/S hose that wanted to leak.
  19. IronNam
    Looking good! *almost* picked up a set back in May but the seller didn't show up...
  20. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Lower Rear Shock Mount Problem
    So got a little more done on my problem with the truck not laying completely out!
    Problem was the lower rear shock mounts that I had modified some time ago & didn't realty check.
    The lower support was to long & hiting the lower part of the notch = frame not on the ground by 3/4''!!
