Today on my truck I.....
Discussion in 'Off Topic' started by nvrenufedge, Jun 3, 2010.
  1. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    just keep an eye on your gauge and check your radiator from time to time..did you use hose water or distilled? hose/tap water is bad!!
  2. IronNam
    Distilled ftw.
  3. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    yep it's a bodydrop. Basically you build a new frame under the cab an lower the cab mounts an you keep the stock floor where it's at. Hence the name stock floor body drop
  4. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    i got pissed off at my tire/rear end combo and ripped out the 410's and slapped in 356's :evil: ...well hopefully it works cause im still waiting for parts as we speak...hope i got a ride home :ROFL:
  5. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Today I got my 4runner grille from the good ol fedex guy
  6. dillinja666
    damn it got rejected by my ring gear....so if you go to swap to a 3 series 3rd member you are going to need to grind out your axle housing to make the ring gear fit. So i ran out of time with the work day and had to throw my 410's back in. Hopefully when i get more time at work i can attempt this again.. damn
  7. 73TRD
    73TRD Veteran
    Redding, CA
    84 sr5 standard cab short bed, 73 hilux short bed
    got my red/clear tails and clear blinkers and corners. put the tails and blinkers in but my fenders are too f'd up for the corners to fit. im gonna sand down the trim and paint it black. pics soon
  8. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Dude! You can't tease us like that! You know the rules.....post pics, you just can't mention it.
  9. dillinja666
    some geeky pics i took today while i was waiting for my parts
  10. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    ^^^ Now thats better! :lol:
  11. planemos
    planemos Toyotaholic
    British Columbia
    Care to explain why hose water is bad? Or what is the benefit of distilled?
  12. joeynational
    PHX,AZ
    91 2WD
    just because of all the minerals in tap, you can build scaling n gunk up on the radiator..especially if you have hard water..i used to run tap water back in the day, but now nothing but distilled..its cheap at wal mart anyways
  13. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    What was the issue with the ring gear? What year housing/diff combo did you try to put together? I had a few issues using a 77 2wd diff into a 85 4wd housing.
  14. 73TRD
    73TRD Veteran
    Redding, CA
    :nana:
    lol. i took pictures on my phone but i cant send them. network problems or some sh!t. i'll post them soon though.
  15. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
    Started it up to move it away from the grass so i could edge and mow. boy does it need a decent carb. :rolleyes2:
  16. 73TRD
    73TRD Veteran
    Redding, CA
    i have a toyota carb for a 22r. its almost brand new
  17. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
    I have a stock 20R carb... but it needs 30+ vacuum hoses and I just borrowed it to test. I'm in the market for a decent Weber. 22R would be jetted a little rich for my 20R. Thanks anyway!
  18. joeynational
    PHX,AZ
    91 2WD
    got my engine back, going to start to put it back together again right now
  19. IronNam
    everything this man said.
  20. DROPT
    DROPT Addict
    Whales Vagina
    very nice how much?
