Today on my truck I.....
Discussion in 'Off Topic' started by nvrenufedge, Jun 3, 2010.
  1. WallyBman
    WallyBman Member
    Enterprise, AL
    I came home a little early from work, shoved a paperclip into the b+ and fp slots in the diagnostic port, and she cranks and stays running. I read something about that somewhere online, and I have no idea what it means, so it looks like I get to spend some time doing my research... But, hey, its a start, right?
  2. WallyBman
    WallyBman Member
    Enterprise, AL
    Well, it seems it is either the afm or the cor, so i ordered one of each used on the eBay. At only $65 shipped total, it wasn't too bad of a deal. Plus, both have a 30 day guarantee, so I'll replace one, then the other, and if neither fixes it, then it looks like I'll have a spare of each. After that, I'll have to check to make sure that I don't have some sort of intake leak. I'm fairly certain that I don't seeing as how she runs PREFECTLY with the jumper in. If all of that fails, I'll re-jigger the wiring so that the fuel pump will be cut on either with a switch in the dash, or by the key turning on. Come to think of it, I had heard that a trick some Miata owners have is to put a fuel pump cutoff switch in their glovebox so that it is harder to steal their car. I might do that, and replace my ignition switch with a switch and a button. I already have a removable steering wheel, so it would be REALLY hard to drive off with my car. Car security only keeps honest people honest anyways...
  3. Lackey
    Lackey Member
    Memphis, Tn
    91 shortruck
    Replaced my timing chain, valve cover gasket, oil pan gasket, water pump and gave her a good motor bath, I will give her some new shoes here soon, she should be one happy lady!
  4. Blasito
    Blasito Enthusiast
    Plainfield, NJ
    1983 2wd SR5 22R 5spd(man) - Chopped '84 Honda V30
    nadadamnthing... crappy weather:brickknock:
  5. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    Prepped to lower my truck, tried to remove the residue from the ugly purple and teal pin striping, did the first coat of the last few interior pieces I need to finish my interior.
  6. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    did some towing, truck did great with the trailer and the ac on.
  7. IronNam
    need to buff and polish the truck, but i threw some zymol wax on it. some parts turned out pretty.
  8. WallyBman
    WallyBman Member
    Enterprise, AL
    I got some tires put on my wheels and put them on the truck for test fitting, only to find out that I REALLY need to do some more trimming under the hood... I don't know what I'll be able to do to get them to clear being laid all the way out...
  9. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    /\ cutting is def required. My front wells are basically gone in my truck pretty much leaving only the skin of the fender itself.
    I installed a harbor freight air horn on my black truck, now I can go to the football games and cheer them on hahahahah. Actually pretty loud (stock if not better) for being such a tiny electric compressor and 8" horn. While doing this I mocked up where my Hornblasters are going to go on my red truck. Those are gonna be LOUD 200psi 4 horns 1/2 line should be according to website about 160DB or louder
  10. WallyBman
    WallyBman Member
    Enterprise, AL
    I already have cut out fenders... It looks like I'm going to have to cut them up another 2 inches. It seems like I won't be able to go much further without the tires hitting the firewall... Am I going to have to tub the firewall????? Time to buy my own sawzall and angle grinder???
  11. yankeetaco72
    yankeetaco72 Veteran
    Escondido
    82 short /97 Tacoma
    I tell you these trucks look really great layed out on steelies! By the way what type of steelies are those cant really tell?:shrug: By the way your truck looks sic layed out and tucking some steelies!:waytogo:
  12. WallyBman
    WallyBman Member
    Enterprise, AL
    2008 Mercury Mountaineer 18x7.5. I have a LOT of work to do... Somehow it is still tucking lugs in the back. Hopefully I won't have to do any more cutting back there... And thanks, bro!!!
  13. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    Installed the idle up diaphragm that I needed, now truck Idles up when the a/c is on in traffic. ftw.
  14. GrantH
    GrantH Addict
    Hattiesburg, MS
    TRIED to fix my brakes again for the 100th time. Still a soft pedal. No idea what to do.
  15. Blasito
    Blasito Enthusiast
    Plainfield, NJ
    got the motor out, front fenders, bumpers and crap off as well as the bed
  16. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    Started on the BJ flip and replacing the drop spindles. The weather took a turn and it got really cold outside. Had to stop early. My dad and I learned a lot of new stuff with this project. We have never dealt with removing spindles and working with ball joints. I should be able to get one side finished today and hopefully the other too.
  17. eurofreak2002
    B-town 208
    Decided to paint bed, got a fender well done and ran outta paint. It looks like a biger POS now haaaaah
  18. DROPT
    DROPT Addict
    Whales Vagina
    cranked the torsion bars and pulled the middle leaf. also ditched the bumper :)
    [​IMG][​IMG]
  19. Blasito
    Blasito Enthusiast
    Plainfield, NJ
    got buttraped for a helicoil kit 70 bones
  20. WallyBman
    WallyBman Member
    Enterprise, AL
    Now I have an angle grinder!
    HO - HO - HO
