Today on my truck I.....
Discussion in 'Off Topic' started by nvrenufedge, Jun 3, 2010.
  1. planemos
    planemos Toyotaholic
    British Columbia
    1 inch tubing?
  2. jetas
    Today so far i put in a new to me coolant passage and hose, Re-did a ground, popped the battery back in, sat in it and listened to some music then i realized that the amp was not grounded thru a wire but it was still on. Im guessing its grunding thru the case.
    Now im waiting for a mechanic to come help me out getn it running. hope this fcker dnt leave me hangin
  3. six7one_KDR
    six7one_KDR Veteran
    From Thee Island of GUAM,Live's in WASHINGTON / NO
    1976,1979,and also YES a 1973 HILUX
    Gave it a bath!!!!:D
  4. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    i test fitted the 302 and the 02 tacoma bumper :)
  5. IronNam
    grounding through the case, you mustve been like wtf?!
  6. StupidSheet
    StupidSheet Addict
    Canada
    I fixed my timing belt problem I had after replacing the water pump. I also replaced the rear brakes. Going up for sale tomorrow! ;)
  7. scrappydog19
    scrappydog19 Member
    California City, CA
    '94 std. cab
    yesterday i finished putting everything back together after fixing an oil leak. once i had it running again, i quickly found i had no oil pressure! anybody got any ideas where i should start? was just going to replace the oil pump, unless there is a less expensive fix.
    Anybody?
  8. scrappydog19
    scrappydog19 Member
    California City, CA
    '94 std. cab
    this is next on the agenda once i get it running properly. i've got some gnarly hard water stains on all the windows. makes it very hard to see where i'm going.
  9. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
    Said to hell with it and pulled the motor apart. Just have the distributor to mark and pull then the off comes the head. Have the gaskets ordered. Screw it, either way I've gotta do it right? Who's gonna buy a truck with a bad head gasket??? :shrug:
  10. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    I willl how much ?
  11. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
  12. V8_TITAN
    Tampa Fl
    89 std cab
    just posted in the other thread, I would love to buy it man. I only make 100 bucks a week tops so I cant afford it right now... plus im already 600 bucks deep in my motor and its not installed yet...
  13. jetas
    Hell yea dude. I thought to myself "No wonder my neighbor was so willing to give it away..." lol now i kno to keep the case away from metal hahah...
    And well today i dint do sh!t to my truck since the mechaninc that came yesterday told me it dint have compression on 2 cylinders, and for some reason there was massive amounts of fuel coming OUT OF THE INTAKE!!!. Im guessing its either i somehow mixed a vaccum line and a fuel line together somehow, or my cold start injector is spewin toooo much fuel into the intake chamber...
    Anyway, I might be buying a Nissan BUT! the yota is staying. Ima buy a new motor for it wen im able to..
    FML!!!!!
  14. IronNam
    i say just look for the obvious on your motor... my fuel lines are hardlines i think.
  15. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
    No problem man, looks like no matter what I'm gonna have it a while, not much response on the Craigslist front....
  16. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    reworked suspension geometry and mounted my rack and pinion.
  17. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Dropped off my 20R head at the machine shop.
    Explained to him that "stage 5" LC valves and seats actually fit in the chamber. :lol: Told him to intall those (with critical valve stem height difference noted), mill it 50 thousanths, install valve guides, clean and pressure check the coolant (in case the seats ate into a passage).
    He told me around $350-450. And getting it back in a week and a half.
  18. V8_TITAN
    Tampa Fl
    89 std cab
    holly hell man thats a lot of money to spend on your head...
  19. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
    Slapped the head back on after cleaning it all up. Tonight is the fuel pump, distributor, and intake.
    Step by step. :waytogo:
  20. Raffaelli
    Houston
    82 Longbed 2WD
    A thousand bucks,.........A dent in the wallet.
    Destroying a v8 Mustang........w/ a 22R.........Priceless :lol:
