Today on my truck I.....
Discussion in 'Off Topic' started by nvrenufedge, Jun 3, 2010.
  1. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    I scored big at the junkyard today! Went to get a set of rocker assembly for my motor I'm building, and ended up also getting a fender better then mine, both taillight lenses (no cracks!), some seat belt buckles, and nearly perfectly straight doors!
    Even better was I barely had to do anything to get all of it, most of the work was done for the rocker assembly, most of the screws were out of the taillight lenses (only had to do 4 of the 12), the fender was laying next to the truck, and the doors were easy since both fenders were off already..
  2. Gr8KornHolio
    Gr8KornHolio Veteran
    Dallas, TX
    85 regular cab longbed 22R
    Scored a solid back window for my 85 reg cab. Guy is interested in buying my slider and stock front suspension parts. :headbang:
  3. suicidedyota
    suicidedyota Member
    Independence ky 41051
    89 bagged yota
    I tore my frame down to do a full frame from firewall back.
  4. first80toyota
    Pacific Northwest
    '77 Hilux
    Not on my truck, but got my block, pistons and rings from machine shop and ordered a gasket set, full bearing set, timing set with steel guide, and head bolts from engnbldr..
    Now my coworker needs to get my head done and I'll be set:waytogo:
  5. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Yeasterday I pretended to be a fancy French waiter and brough myself a plate of hilux. :lol:
    And on Friday I hauled in a 1500 lb load of scrap metal with the lux. I make him earn his rent like a proper ho...stuffin' the rear full :ROFL:
  6. standardbyker88
    lynnwood, wa
    Upside down pic. Odd. Try a diff angle.
  7. KERTWOOD
    KERTWOOD Enthusiast
    Atlanta
    92 Street Truck
    Today on my truck I..... did absolutely nothing. Waiting on parts suck.
  8. Ghostwhite
    Ghostwhite Enthusiast
    Las Vegas
    86 reg/long 2wd
    Changed oil, was 30,000 miles overdue according to service sticker in the window. Found dizzy vac adv actuator was blown, ordered new one from lc. Replaced a bunch of vac lines and emissions hoses. Need to install shocks.
  9. raylcc
    raylcc Addict
    Denver, CO
    I ordered an older Rockford Fosgate 18 inch subwoofer. (not sure of the year, Pretty sure it was among the last years they made them.) Now when it arrives I have to find a place that will put a fresh surround on it and hopefully I can find a vintage "The Punch" dust cap to have installed on it. I'll be mixing years, but I want the old school, 80's-early 90's look for it.
  10. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    Wow, only 30k overdue...and i thought i was a procrastinator...lmfao
  11. Ghostwhite
    Las Vegas
    86 reg/long 2wd
    Gotta love Previous Owners! I am gonna replace some seals and gaskets and if this thing won't quit leaking I'll be nearly forced to do an LS swap! Poor me :D
    I need to sell my kart or something to fund that.
  12. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    More work on my winter project. Got the drivers side mirror mounted,just have to make a small adjustment to it ,than make inside support brackets ,fill the stock holes,repaint & on & on !!!:cool:
  13. Echonova
    Echonova Newbie
    I cleaned out my garage/truck and washed it.
    Looks so good wet...
    Dry, not so much.
    Nothing a rattle-can of the finest flat black can't fix.
  14. NWA STEVE
    NWA STEVE Enthusiast
    missouri
    1987 toyota xtra cab longbed
    took the truck to street driven customs to get a bead rolled bed floor done and have a new raptor linner sprayed in.[​IMG]
  15. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Drove it....hauled a ton of stuff to dump...bagged trucks can haul stuff!!!
  16. standardbyker88
    lynnwood, wa
    So can super statics. I hauled in 1500 lbs of scrap a few weeks ago in my 78. Lol
  17. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    I now have second gear in my 90 again. I had a busted shift fork due to stupidity on my part. It's nice to have the truck back in action. :D
  18. CUCUY
    CUCUY Enthusiast
    HOUSTON
    '81 SR5 longbed
    lets see....
    i replaced my valve cover gasket along with the grommets
    spark plugs
    spark plug wires
    distributor cap & rotor
    oil and filter
    fuel filter
    air filter and new a/c belt and alternator belt
    and lastly cleaned the carb and engine bay from leaking gasket.
    drove it to work the next day only to get to work and come out after work and see a HUGE oil spot under my truck of fresh oil! opened the hood and oil everywhere!
    turned out to be the crankshaft seal.
    drove it home and let it cool down. pulled off the fan/clutch, the new belts i just replaced (now covered in oil) and pulled off the harmonic balancer. pulled the seal out and inserted a new one. reinstalled everything back on and BAM, oil leak fixed!
    now i have to really clean the engine bay as the pulleys threw that oil everywhere!!!
    /rant.blog.cucuy
  19. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Had a new clutch master and slave cylinders put in
  20. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    I put new rotors on......
