my truck on C4 vette wheels... aka salad shooters. 16x8.5, 32+ offset (used with 1.25" adapters witch push the wheels out to a -2 offset) mounted on 195/50/16 tires...
Mitsubishi 3000GT rims 16x8 +44 Upper ball joints would rub on lip of the rim. Had to change uppers to 1995+ 2wd Tacomas. Used Autozone spacers so rear would not run the leafspring mounts. Toyota Prius center caps.
Here's my 17" Lexus ISF snowflakes. +35mm offset. 7.5" wide. Bores 73.1 so I had to run the bore adapters.
where do you get bore adapters? I just picked up some crown vic cop car steelie 17's and the bore is too large.
Yes where did you get your wheel adapters?!! My miro 398 18x10.5s just arrived and the rears clear the center bore amazing but the front wont fit over the center hub. When I did my research it said our hub size was is 60.1 and like yours udream69 the miro bore is 73.1. Any help would be awesome fellas kinda stuck here!
They sell them on ebay, just look up hubring or hub centric. I Just was about to put rims on my kids Toy and the fronts didn't fit either so I had to get one in spacers to make them fit. 1" 5x4.5 Hubcentric Wheel Spacers 5 lug fits Lexus Scion 60.1mm Hub 2 Pcs 1" 5x4 5 Hubcentric Wheel Spacers 5 Lug Fits Lexus Scion 60 1mm Hub | eBay
yes, the problem with mine was that the rim didn't fit over the grease cap so I couldn't get the rim center cap on so I had to use spacers on mine. I have the same size center hub as you as well
