SVS's "SupraTruck" Build Thread
Discussion in '1989-1995 Build-Up/Project Threads' started by Sound.Vision.Soul, Feb 11, 2009.
  1. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    Nope im not using the factory tach I wired in an aftermarket one.. little easier. But for our tachs you need a cluster out of a v6. The tachs out of a 4 banger are calibrated for a 4 cyl.. A 6 cylinder wont read correct even if u did get it wired.
    Just a random question tho...... would u be willing to natch a oil pan for me or whoever did yours and ill pay you??
  2. Dcups
    Dcups Addict
    Seattle
    93 Std Cab chassis/4Runner 2door body
    Id PM Blacklightnin55 he is the one that notched his pan not me...
    You can always build a different draglink bar to clear the pan i saw some one build one but cant remember who.
  3. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    Yea i bent my pitman and idler arms down... works... but does not drive like it used to or should.
  4. IronNam
    thats unsafe.... lol
  5. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    Yea was not the best way to do it.... lol :shrug:
  6. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Bringing an old thread back!:lol:
    You could also bent the center link in the middle so it clears the pan, since that won't effect geometry of where the center link to tie rod pivot locates. That causes bump steer which isn't safe or intended.
  7. standardbyker88
    lynnwood, wa
    Actually thinking about that, it would effect the proportioning between left and right sides of it due to pitman/idler geometry being changed. You could make a notch in the center link, but its cast iron. I'd say adjust the motor/trans mounts to make it clear everything.
  8. Blacklightnin55
    Blacklightnin55 Member
    Louisiana
    1990 Ext-cab
  9. Mayhem Industriez
    Mayhem Industriez Member
    Cypress, TX
    91 single cab
    Man your truck is coming out awesome! I am considering doing a motor swap in my pickup but I am having a hard time choosing between the 3.4 V6 supercharged or the 7mgte. What do you guys think?
  10. 91lowyota
    91lowyota Newbie
    saint petersburg fl
    1991 toyota pickup
    so i know im probably diggin this thread up but,, im currently working on the same project, but fully building my 7mgte. i have been reading alot of threads but cant seem to find how to wiring this thing in! what clips are needed from the old harness? any relay i need out of a supra?
  11. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
  12. loluxprogress
    loluxprogress Enthusiast
    VIC, Australia
    1994 Toyota Hilux 22R
    im glad your putting the 4x4 guards on. make front look way tougher. put a chrome 4x4 bar on as well, so it comes out to the flair on 4x4 guards.
  13. 91lowyota
    91lowyota Newbie
    saint petersburg fl
    1991 toyota pickup
    ok thanks! i see it all now!
  14. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    how much of a pain in the @ss is it to pull the whole dash out? also, can you just pull the dash pad off with removing the whole dash?
    thanks
  15. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    You dont have any spare injectors laying around do you? ;)
  16. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    lol sry man. i sold the old v6 engine complete. Im surprised i got anything for it at all!
  17. joeyota653
    joeyota653 Enthusiast
    hoiiii!
    bump for a cherry xcab!
    just curious.. whats the weight difference with this and the old motor?
    and hows the truck around the corners??
    considering this swap:D
  18. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    Well im not sure about the weight difference.... but im sure its not far off 50 pounds different. As for the cornering... well it is a truck still.... but the suspension work is slowing comming together.
