Supra Guts in a 75 8" Diff
Discussion in 'Engine/Drivetrain' started by Seventy6Celica, Feb 3, 2013.
  1. Seventy6Celica
    Seventy6Celica Member
    San Gabriel Valley
    75 Hilux
    Just an FYI, because I was told it couldn't be done. I just installed an 88 Supra LSD and 3.91 gear set into my 1975 8" R&P 2wd Hilux. I would do a write up, but this link does a way better job.
    Toyota gear install
    To do this install you need a late 4cyl inner pinion bearing and race and the axle carrier conversion bearings, or do what I did before I found out about the conversion bearings, and machine the axle carrier down to accept the 4cyl bearings. Also the guy on gearinstalls.com lists a koyo bearing number. I couldn't find that number anywhere. Turns out it's sold under National bearings, part #32307-W. The "W" is very important. That's what makes all the difference. It's a thinner bearing than what's stock in the 85 and older diffs. If you don't use that bearing, the pinion will hit the carrier/LSD. Well, I guess that's about it. Good luck, and have fun doing 2wd burnouts.
  2. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    best stuff to run a redline 75-90 with no additive since it's all ready in the fluid.
    and I recommend wise spring upgrade since the supra lsd is pretty slushy in worn stock form
  3. zatoh
    zatoh Newbie
    wow. pretty detailed log there too.
  4. smartmonkey
    smartmonkey Veteran
    Australia
    v320, 620, 720KC, RN46, LN46, YN65 & B2200
    Is it possible to do the supra conversion into a 4x4 83?
  5. Seventy6Celica
    San Gabriel Valley
    75 Hilux
    If it's an 8" rear end, then yes it's possible.
  6. smartmonkey
    smartmonkey Veteran
    Australia
    Thanks mate
