Sticky gas pedal
Discussion in 'Maintenance/Repair' started by Shoosty, Apr 14, 2021.
  1. Shoosty
    Shoosty Newbie
    1st 10% of my gas pedal pressure is high and its hard to get a smooth rev. any fixes?
  2. fred heath
    fred heath Addict
    Raleigh, NC
    Check your linkage for binding. Check behind the pedal hinge for blockage. Lubricate the pedal hinge.
  3. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    on my 93 it had a similar issue - cleaned the intake manifold/butterfly and it went away
    Erwin Merida likes this.
  4. sirdeuce
    sirdeuce Veteran
    '86 4Runner and '89 2WD
    Carby or EFI? If it has a cable it might need lube or replacing. My '86 4Runner has the same issue, EFI. Has a frayed cable. Needs to be replaced.
