Steel blocks & low profile rear bump stops
Discussion in 'Suspension/Chassis' started by Beefed Taco, Aug 19, 2009.
  1. Beefed Taco
    Beefed Taco Addict
    My cross member mod known as the Beefed Bridge...redrill new hole, cut out C/M, and weld in the Bridge. I know your truck's a bit different though.
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    good lookin work again. my truck doesnt have a crossmember like that though, it has one that hangs way too low and mounts the carrier bearing to. im gonna cut off what hangs low, and plate the bottom with flat plate. ive seen that done on here, and done it on a few trucks. works good.
    see what i mean. itll be thick plate, since there wont be much of it left. the notch in it for the exhaust needs to go up taller too. i may shim the carrier forward and up a bit. i remember that its pushed forward to the end of the adjustment. longbeds had 2 part drivelines.
  3. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Wow dude you got some sick parts. What else kinda parts you make?
  4. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    wich one? :evil:
    these trucks have soooo manny avenues to go through on notching. they are waaaay too easy. best of all, these are thicker frames so even if you are to cut into them they still hold up well. the notch we did for mine (although ridiculous) is holding strong....... :waytogo:
  5. Beefed Taco
    Beefed Taco Addict
    Click my signature and it'll show some stuff. I really do want to get moving on more pre 95 stuff though for sure, as I love the hell outta those trucks, and you guys deserve more options.
  6. ryan1979nz
    ryan1979nz Newbie
    New Plymouth, New Zealand
    '88 Hilux SR5 xtra cab (jdm 3y version)
    Hey man, I need some of these bumpstops for my 88 jdm hilux sr5....
    Do they fit front and rear? Can the steel bit be painted black before the
    bumpstop goes on so it looks closer to factory or are they premade.
    Could you post a set to New Zealand? How much am I looking at for a
    full set. Paypal and US$ is fine....
  7. Beefed Taco
    Beefed Taco Addict
    PM sent. Sorry for the late reply.
