Starter Terminals 20R out of a 1976 pickup
Discussion in '1976-1983 Pickup Discussion' started by Fix it up, Nov 19, 2022.
  1. Fix it up
    Fix it up Newbie
    the starter has one mail plug for the starter wire but also has a small terminal with a screw to connect a wire. I am wondering what the screw connector is for and how to connect it. It's the terminal under the blue wire.
    Thanks
    Fix it up
  2. jetas
    There should be spot for a heavy gauge wire from the battery and a small wire that is the starter trigger wire from the ig ition switch
  3. Fix it up
    Fix it up Newbie
    Yes, but it also has the one seen in the picture. The starter trigger wire goes on the other side.
  4. Fix it up
    Fix it up Newbie
    Upon more testing the screw terminal sends a 12 volt current when the starter is turning over but quits when its not cranking. No idea what is suppose to be sending power too for that cranking time.
    Fix it up
  5. fred heath
    fred heath Addict
    Raleigh, NC
    Check your factory wiring diagram. If you have an in tank fuel pump that could be part of the bypass circuit.
    Keep in mind this starter could be used on different applications besides your particular engine.
    If no obvious extra wire hanging loose, I’d just ignore it.
  6. jetas
    Sounds like Fred hit the mail on the head. It's probably for the bypass circuit. It's set up to send current to the pump while cranking
  7. Fix it up
    Fix it up Newbie
    Thanks Guy's I ignored it and it works fine. I put a separate pump and switch when I installed it in the Bombi.
    10 times the engine that was in it.
