Starter Relay ???
Discussion in 'Engine/Drivetrain' started by Reddawg007, Mar 5, 2009.
  1. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Photos of what?
  2. One ton
    One ton Newbie
    Photos showing the wiring to add a ford solenoid.
  3. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
  4. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
  5. One ton
    One ton Newbie
    Finally picked up the solenoid. Now trying to make sure I get the wiring right, I’m still a little unclear.
    Here are my 3 questions:
    Connect the starter to #2?
    Connect both battery terminals to #1?
    What’s connect to “the switch” ?
    thanks in advance!
  6. jetas
    Not sure which is 1,2 or 3 but i have mine like this (with the smaller studs at the bottom)
    -Big left stud-- B+(Large gauge wire)
    -Small left stud--starter trigger from ign switch
    -Big right stud--to starter positive post(large gauge wire). And then a 10awg jumper from the starter+ To the small trigger connection on the starter.
    hope this makes sense
  7. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
  8. One ton
    One ton Newbie
    Is this (black wire with white) the starter trigger from the ignition switch?
  9. jetas
    More than likely yes. Turn the key and check for voltage. Should only have + when in the "Start" position
  10. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
  11. One ton
    One ton Newbie
    So literally have been trying to get to this, but parenting has taken precedent… finally wired it up today and still getting just a click when I try to start. Battery is new as of 10/22.
    The photo has 2 wires on the left stud?
    Full disclosure, in the two years I’ve owned the solenoid (master pro 2SS5) that I just put on, I’ve dropped it on the ground and then also I cracked it over tightening small left stud. Not sure if that may have done something. :verdict_in:
    Anyone's help is very appreciated
  12. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    I would check battery voltage at this point if it sat for 2 yrs and no charge. Dropping it may have dislodged a contact point but highly unlike since these parts are designed for vibration. Recheck that your feeding voltage to the starter solenoid, and it's tight. Are you missing any grounds?
  13. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
