Sputter & shaking!!!
Discussion in 'Engine/Drivetrain' started by crashburnoveride, Jan 22, 2013.
  1. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Clogged injectors can give you hesitation and sputter and spit run a few bottles of seafoam and Lucas burn hot over a month or two or marvel mystery oil I prefer marvel it seems to work on everything then change your fuel filter
  2. MilehighHilux
    MilehighHilux Enthusiast
    First do a power balance test. See if your running on all four cylinders. Them compression and leakdown test. Then start trouble shooting injectors spark plugs etc. start with the easy stuff work your way up
  3. crashburnoveride
    crashburnoveride Member
    Lincoln, NE
    88 reg cab pickup
    Well its stupid cuz now that I want to be driving it everywhere to burn all that seafoam through it I have a wicked loud vibrating sound comng from my left front wheel. Only happens for 20 seconds tops but its quite annoying and I dont wanna drive on it alot until I know what THAT is... jeez! One thing after another!!!!
  4. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Jack it up check the front end maybe . loose caliper bad wheel bearing give it a inspection lucky front end parts aren't to expensive
  5. crashburnoveride
    Lincoln, NE
    88 reg cab pickup
    Its 1 degree outside. Fk that.
  6. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Lmao I here ya . Double F that
