they are. keystone vortex. came with the truck when i got it. there was a little rust on them but nothing a little rust stop paint and turtle wax chrome polish couldn't handle
those tires were bigger than 60. i have 75 series on there now and the sidewall is at least an inch shorter
yep it did, 800 dollars later its mine, the vavles were way outta adjustment, got that fixed, then the sob got a rod knock, so ive been slowly working on it. bought a used motor, timing chain guide was busted, so i put that engine on a stand, all i gotta do is finish assembling it and im done
Unsure of wheel brand but its a 16.5x13 8 on 165mm Super Swamper TSL 38x12.5x16.5 Rubbers. Havent been cleaned in a while as you can tell from the pic.
would like to know if the guy thats running dodge magnum wheels had to have your center bore bored out im planning on running hte same wheels set up I already have the wheels just not the truck yet i want to be able to put all the toyota center caps on also witch caps did you take them off thanks.
