Shifting problem
Discussion in 'Engine/Drivetrain' started by yota4life, Apr 27, 2010.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I noticed the other night that when it gets hard to shift an I push in the clutch it feels like it's gonna die. Could it be the clutch master cylinder?
  2. CHOPER211
    CHOPER211 Newbie
    issues taking out the shifter....
    im trying to take my shifter out now....but it wont go down very much when i push it and it wont turn counterclockwise at all its very hard it only goes down a few cm not very much im trying using a vise grip as well and thats not helping much either.
  3. 915toy
    915toy Member
    ^^ been trying to turn the metal piece all morning, won't budge...any help?
  4. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    I have used needle nosed pliers to push it down and turn it by spreading them to both sides at once. I've also used a pair of flat tip screwdrivers with perfect success.
  5. 915toy
    915toy Member
    Im going to have try the pliers method tomorro....howd u use the flat tip?
  6. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    I had the same problem taking out my shifter too, wouldn't go down at all, turns out mine had 4 10mm bolts/skrews to remove then the shifter jus pulls sraight up from the tower.
  7. 915toy
    915toy Member
    Where we're those 4 bolts at so I can check if I have them too?
  8. White Trash
    Eastern WA
    If you have a round rubber boot at the base you have either the push & twist collar or an internal snap ring. If the boot I'd squarish you have bolts.
    I use the screwdrivers to push down at the corners of the collar and pry against the handle. Hard to explain, easy to do.
  9. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    On the top of the tower under a rubber cap
    The bolts are what hold the shifter down in the tower
