Shifter bushing
Discussion in 'Engine/Drivetrain' started by Ivey, Dec 5, 2018.
  1. fred heath
    fred heath Addict
    Raleigh, NC
    Both plugs take the same size socket (23mm?). They’re close to each other so easy to confuse. I’ll try to upload a picture of what this plug should look like when removed.
  2. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    I finally got under the truck today to take a look at this and came to the realization that I drained from the wrong plug and that when I drained the transmission I actually replaced the plug with a hex one. I luckily keep the old plug but the problem is that it doesn't have a spring or a ball bearing. I purchased some ball bearings ahead of time but had no idea I would need a spring. So this is definitely my issue just trying to figure out how to remedy it.
  3. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    I think I got it fixed. I found a picture someone took on Yotatech of the spring and ball. Went to the hardware store and found something similar, 3/8in in diameter. It was too long but I cut it down so it sat flush with the top of the bolt. Greased up the bearing and put the whole thing back in there. I shift a lot better now. I can go straight from gear to gear without having to stir the pot, so to speak. Thanks Fred!
    fred heath likes this.
