Return of the Minitruck Jedi
Discussion in '1989-1995 Build-Up/Project Threads' started by SD YOTA, Feb 17, 2013.
  1. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    clamped on slip fitted exhaust isnt a bad thing... it holds together just fine so long as the clamps hold tight.
  2. KERTWOOD
    KERTWOOD Enthusiast
    Atlanta
    92 Street Truck
    Whats the truck look like with its new Shoes? I'm only assuming..:D
  3. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    I have the apexi neo from my 4runner still
    and you can get away with stock injectors tell ya do cam shafts then get a set of 7mge ones I think I never did the injector swap I just over drove the stock ones and it worked
  4. staticroyal
    staticroyal Member
    I am Barrack Obama, & approve of this build thread!
  5. NashMan
    NashMan Toyotaholic
    94 2wd
    ^ Don't you have obama care to work on right about now
  6. SD YOTA
  7. jctoy29
    jctoy29 Addict
    surprise,az
    Thanks for coming out folks! (Obama voice).
  8. SD YOTA
    just a small update but i installed my 4runner fenders and clear corners a few days ago... modified the headlight housing mounts and cut into the core support so the housing tabs sit flush.
  9. patrickgraven
    patrickgraven Veteran
    Corona CA
    93 2wd pickup "home depot" / 2004 Toyota Sequoia 4x4
    How are you running the c4's? Are you running adapters or did you have the wheels re-drilled.
  10. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Probably adapters. A guy on here had a set on a 77ish lux too. Better than your dumb plastic hub caps :ROFL:
  11. beyondspexj
    beyondspexj Addict
    Sin City
    85 Pickup
    do you have a write up of modifying the core support to accept the 4runner headlights?
  12. SD YOTA
    @ patrickgraven, yea, 1.25" adapters.
    VERY much better than the STAINLESS STEEL hubcaps... thank you very much. lol
  13. SD YOTA
    its pretty simple, but ill take some pictures and post them here. i had to bend the very outter edges of the core where the headlights go and drill two holes for the outter bolt holes to have a mounting area. then i cut a notch into the top inner core area where the tab needs room to bolt into the core flush.
  14. SD YOTA
    a few night shots of the truck while it was rainy... and some when i visited Hoshposh
  15. FOKAI
    FOKAI Veteran
    SD
    84 truck, 05 4Runner
    Sik! Any rolling shots with the Vette wheels?
  16. SD YOTA
    not yet... at least not any good quality ones...
  17. SD YOTA
    So a few more updates to post today... I've been busy trying to knocl out my list of mods for torc and I'm actually getting allot done..
    Here I spent most of the day messing with my factory 1ton bar. After messing with angles... I finally got it right!
    Ill be doing a writeup on this soon...
  18. SD YOTA
    The latest yet first thing I ever wanted to do to my truck finally made its way onto it as my solid rear window is now on and pimpin the fish bowl status!!
  19. FOKAI
    FOKAI Veteran
    SD
    Wanna swap with the Supra?:)
  20. SD YOTA
    hmmmm.... hahahaha. very tempted but nah... i love my truck
