Return of the Minitruck Jedi
Discussion in '1989-1995 Build-Up/Project Threads' started by SD YOTA, Feb 17, 2013.
  1. ITMONEY
    ITMONEY Enthusiast
    Is this with the stock manifold and crossover on that 3.0?
  2. Bradthreee
    Bradthreee Enthusiast
    Palmdale, Ca
    1990 xcab
    Bad ass man!
  3. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    yes, i did have the tailgate down when building this system.
    thanks man. ill get a better video later tonight.
    yes it is. im thinking about deleting the stock crossover behind the motor and run individual down pipes into a better crossover pipe under the trans.
    thanks!
  4. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Good job buddy. I figured you're smart enough to check gate clearance. A slight angle cut on the tips might look good. Like a few degrees off of a vertical cut, tipped back from bottom to top. If that made sense.
  5. SD YOTA
    yea, i got what you meant. im waiting on some stainless steel tips for these pipes... not sure what my buddy ordered but we shall see...
    i do personally like the "shotgun" tip effect though. i would like a pair of plugs that have a red flag reading "remove for liftoff" kinda like some aviation jets have... lol
  6. standardbyker88
    lynnwood, wa
    You should get some red fabric, make a piece to wrap around the tip. About a foot long. Cut it into strips most of the way down the length. Use a hose clamp to hold it onto the tips. Then you can have your very own wacky waving arm inflatable tube man! :ROFL:
  7. SD YOTA
    :lol: LMAO!!!
  8. standardbyker88
    lynnwood, wa
    *starsky and hutch undercover voice* do it! Do iiittt!
  9. standardbyker88
    lynnwood, wa
    If you don't, I probably will. And if you're wondering if using a tall boy can with the ends cut of works, nope. The exhaust pulses actually crimp it shut. Using it as an extension tip anyways. My exhaust tip is about a foot from the edge of the body in front of the driver back tire. Didn't want a visable tip for cops to spot when they hear noise. But I have a resonator tip I found in the freeway I'm gonna use eventually.
  10. SD YOTA
    yea, i thought about the monster cans too but im not sure... gonna buy me a monster tomorrow n play with it..
  11. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    I dig the exhaust! Obviously...
  12. SD YOTA
    thanks man.... its always been my favorite type of exhaust style... :evil:
  13. SD YOTA
    so its been a while since i updated this thread. not too much has gone into the truck but a few important upgrades happened. i added all new energy suspension bushings all around to improve the ride quality. upgraded my front torsions to 1ton 25mm bars, 1ton 25mm front sway bar and i picked up a rear sway bar im working on mounting right now. i also got some new shoes for the truck as well!! 16x8.5 C4 wheels with 195/50/16's... although they rub a bit, ill be getting some 205/40/16's instead and allow for more room.
  14. SD YOTA
  15. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    you should get a mk3 supra afm and then set of cam shafts
    you will be blown away from the added power
  16. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    That new exhaust is sic!!
  17. SD YOTA
    yup, those are all next. i hope to have time to install the headers in by next week... the afm is also coming in next week. cams im doing some research and comparing prices and such.
    thanks man... i hope to have a really nice mean sound out of it when the headers get put in! :clapping:
  18. NashMan
    NashMan Toyotaholic
    94 2wd
    I know what cams to run the guy at colt cams makes the best ones you can ether get all new shims or he will give you the shim to go under the stock buckets
    ps you will run out of fuel very soon after words so you will need to over drive your injectors or get new ones
  19. SD YOTA
    yea... before i do cams im gonna make sure to have some balanced injectors at least, and possibly look into that apexi setup.
  20. 89blaster89
    89blaster89 Enthusiast
    western wa
    93 singlecab
    damn thats sick, im gonna redo my exhaust now, mine is all clamped together and is pretty ghetto
