Ressurecting my 91!! 2rz swap!
Discussion in '1989-1995 Build-Up/Project Threads' started by joeynational, Apr 30, 2009.
Tags:
  1. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    No, been so busy with school..I have most of the parts, school is over on Tuesday for me so I'll have some time to finally make these. I'm going microcontroller so still figuring out the programming I need to do for them as well. I got the sequential code down but still working on the other animations. I'm going for sequential, strobe and maybe fade. I want to make it selectable with a button..we'll see though
  2. Zombie Monarch
    Zombie Monarch Veteran
    Springfield, MO
    1991 single cab dually hilux
    How many bulbs are you going to use row x col? IE 1row of 10, 3 rows of 12?
    I think if you had enough rows it would be cool to also add a sort of bullseye effect where it starts in the middle and expands out or vise-versa.
  3. joeynational
    PHX,AZ
    91 2WD
    3 rows of 10..The possibilities are endless! That sounds cool too..My goal would be, when the truck starts it would go into an "animation mode" and run through a series of animations. Once done it would be a regular turn signal and would blink however i had it set..Something like that might take me a while to figure out...
    Whats up with your projectors?
  4. Zombie Monarch
    Springfield, MO
    I need to figure out where I'm going to relocate my batt to and put them in and they will be done.:brickknock:
  5. joeynational
    PHX,AZ
    91 2WD
    Had to stop and take this pic the other day!
  6. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    thanks...thats the one i remember reading awhile back...you scraped, sanded? what grit did you use on sumthing like that, like a 600grit?
    also, in that pic it looks like u painted some white, is that what i see?
  7. joeynational
    PHX,AZ
    91 2WD
    I started by scraping but was taking much too long plus i was putting grooves in it..So i used emery cloth, not sure of the grit but just regular emery cloth..came off much easier!! At the end i switched to alcohol and was even easier..
    Nothing is painted on the gauge faces, i think its the glare that makes it look white..but I used photo film on the tach's red area to really make it red, because it was a nasty faded red after sanding..You can get the film free from a photo shop in your area..its a sample booklet..the name of it is in my thread i think..I think its called roscoe something..don't remember
  8. joeynational
    PHX,AZ
    91 2WD
    the info on that film is on page 6
  9. joeynational
    PHX,AZ
    91 2WD
    Got the prototyping done on my newly coming turn signals..I'm going to try and have another flash sequence which will be selectable by push button. Probably gonna go with a strobe flash, here is my sequential flash
    <iframe width="420" height="315" src="http://www.youtube.com/embed/04sHDp1wQbw" frameborder="0" allowfullscreen></iframe>
  10. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Thats going to look sik. I give it 2 thumbs up
  11. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    That is sick. Hope you are able to make some extra sets to sell some of us. Cant wait to see the taillights.
  12. joeynational
    PHX,AZ
    91 2WD
    thanks guys! Depending on how these come out and how much its costs I may consider selling some
  13. joeynational
    PHX,AZ
    91 2WD
    Finished my first custom circuit board, designed, etched, drilled and populated by yours truly! Programming for animation was also done by me.
    Printed layout from Eagle CAD
    after ironing on the layout on copper clad board, and dropped in etchant
    during etchant process
    after completely etched
    wiping off mask to reveal copper
    after drilled and populated ready to rock!
    This has a 10 channel output, animation can be changed..all i have to do is take out the microcontroller and reprogram
  14. joeynational
    PHX,AZ
    91 2WD
    here is the LED board, not done yet..still have to cut out to fit turn signal housing. Put the chrome front on and solder LEDs and connections..
  15. Zombie Monarch
    Springfield, MO
    Turning out freakin' stellar man! When can I buy my set? =D
  16. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    you my friend are crazy lol
  17. Da_Roach
    NOVA
    Nice work. Hope you sell some sets. I'm gonna be getting in line for this.
  18. joeynational
    PHX,AZ
    91 2WD
    haha thanks!
    Thanks guys! If i'm going to sell these I would like them to be a little nicer, the traces on the board are not as detailed as I would like if I were to sell them, gonna try an alternative to magazine paper for transferring the layout that will make the transfer much more precise and detailed, here is an example of how it "bled" a little bit, and you can see the pits in the copper..would like to get it completely filled
    If the demand is high enough, I may even send my layout to a professional and have them done up proper!!:waytogo:
    They do work tho!!:D
  19. Zombie Monarch
    Springfield, MO
    On the video's I've watched they say to use glossy photo paper, is that what you used?
  20. joeynational
    PHX,AZ
    91 2WD
    no i used magazine paper, i read it works well and is obviously cheap if you have old magazines..It works ok for me, but if i'm going to sell these I want it better..Gonna try Press n Peel blue next!
