rear porprotioning valve
Discussion in 'Engine/Drivetrain' started by yota4life, Aug 3, 2009.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    still not sure on what to do.. should i just T it off and be done with it or should i try and move the stock one
  2. Shadetree Mechanic
    Shadetree Mechanic Addict
    Emerald Triangle, CA
    :shrug:Strange. Both my '79 4x4 and my '89 2wd came with one.
    At any rate, I think that possibly the best solution would be to eliminate the stock LSPV and replace it with an adjustable proportioning valve.
    http://www.chevyhiperformance.com/techarticles/71398_install_brake_proportioning_valve/index.html
    I think the Wilwood proportioning valve they used in the article would be a great choice but there are also a variety of other models out there.
    http://www.jegs.com/p/JEGS/JEGS-Adjustable-Proportioning-Valve/755192/10002/-1
  3. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    im just on a budget right now and cant afford one
  4. Shadetree Mechanic
    Then just t it off. I really don't think it is an immediate safety concern since you are not planning to haul much with it. A t is pretty cheap. Then again, bending the rod to reshape it is free, if you want to go super lo-buck, that might a way. At some point down the road when you have a few extra bucks spend the $40 and get a proportioning valve so you can really dial it in. I think the proper way to do it would probably be to add a manual proportioning valve.
  5. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    what kind of T do i need?
  6. Shadetree Mechanic
    You got me there. I mean I don't know what thread pitch it is. I would try to take the LSPV with you to the hardware store so you can find a t that matches up. Make sure you get the kind with straight threads, not a pipe thread! You want it to seal on the flare, not on the threads.
  7. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    haha alright ill ask around some more thanx for your help man i appreciate it alot
