Ok not sure what’s going on here. But my rear passenger side wheel is sticking out approximately 1/2” to 3/4” compared you he drivers side. i can’t positively say it was this way before the installation of 4” drop blocks but it’s definitely noticeable now. my question is could the rear end have shifted slightly to the right when we bolted everything up? Would a fix be to loosen the u bolts and try to shift the axel over to the drivers side. one thing we removed when installling the blocks are the housing that binds the springs together because the aligning hole in the blocks were too small to fit into the spacer blocks.
Are the U-bolts canted? If they aren't at a 90 degree angle to the axle housing loosen them up and try again.
Sounds like something is definitely not installed right. Undo all that you did. Make sure the blocks are centered and sitting the leaf spring centering bolt and make sure the acle is sitting correct on the block. All the pins gotta line up. If you for some reason took centering pins out, put them back. Theyre there for a reason
I think he’s saying he removed the center bolts that hold the springs together, also used for locating the axle in the vehicle. In which case yes, you most likely have the axle not centered , loosening the u-bolts and aligning it should take care of this issue, but the centering bolt should be re-installed and the blocks drilled out to accept it, the head is a 21mm, I used a 13/16” drill bit for mine and it worked fine.
