Ok. Raise tue truck n put it on jackstands. Unbolt the shock from the lower mount. Loosen the U-bolts. And raise the axle off the leaf springs Grab a some vice grips n make sure ur holding the pin tight and loosen the nut from the bottom. Get the short thick bottom leaf and place it ontop of the leaf pack n do everything u just did but backwards
I got 3" blocks, cranked the front & the ride sucks.lol Thinking about pulling the middle leaf tho, still want it lower. I love the stance tho sooo not sure what imma do yet haha.
do the ball joint flip up front in order to regain some rigidity in the bars. this would be equivalent to a "mini" spindle drop. if you pull the middle leaf from the rear, i would suggest either a) air shocks since it may get soft and smack the frame once in a while or b) notch the frame. truck looks real nice though!
