Random Other Projects Thread
Discussion in 'Off Topic' started by Twisted Minis, May 4, 2011.
  1. IronNam
    Seth san, no plans for le intercooler?
  2. Twisted Minis
    Twisted Minis Addict
    Poor Cal
    1980 Toyota
    Intercooler for what? If you mean the Mercedes, you can't run an intercooler on draw through. Since the fuel runs through everything, and intercooler becomes a potential bomb.
  3. Twisted Minis
    Poor Cal
    1980 Toyota
    Show coverage.
  4. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Love your work man looks so good
  5. Twisted Minis
    Poor Cal
    1980 Toyota
    I lowered a VW Caddy, a diesel Rabbit pickup. I also did a 2.5" straight exhaust, sounds awesome! Will let the pics speak. First shot is how it came in.
  6. DVSLUX
    DVSLUX Member
    TAURANGA, NEW ZEALAND
    88 TOYOTA HILUX
    Thats pretty cool Seth, never seen one before
  7. Twisted Minis
    Poor Cal
    1980 Toyota
    Really? I think they are pretty cool. I traded the work for this car. I want to find some Fuchs to put on it.
  8. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    wow....... so the coil over top hats fit over the stock strut location? you used the audi spherical bearing thinggie as you mentioned?
    im also seeing a flipped axle...... how much total drop did you achieve with what modifications i can see here? what all did you do for that matter???
    umm......... if i end up with a vw rabbit pickup, care to guess where ill end up at? :lol:
  9. Twisted Minis
    Poor Cal
    1980 Toyota
    Well the strut cap I built replaces the stock ones. The stock ones are not rebuildable. I used an Audi bearing on the top, and built a strut cap to accept it and bolt into the stock location. You can bolt the coil overs to the stock strut mount, and still go this low. But the shock is close to bottomed out, so building a raised strut cap, and using the more low profile Audi bearing gives about another 2" of travel. Makes for a better ride quality, as the shock is not compressed as much, and is working with more fluid essentially. Apparently these cheap coilovers (under $300 shipped) get stiffer the lower you set them. So this allows them to be set 2" higher, and they are set 2.5" up from the lowest setting. So without the strut caps, the coil overs would have been nearly bottomed out at this height.
    In the rear, I did an axle flip, and removed a leaf. And found some shorter shocks, and machined some adapters to make them fit the stock upper mount. Then just enlarged the lower mount holes to 1/2".
    I also sectioned the oil pan and raised the pick up, since the pan is the lowest part of the frame. I welded the control arms to strengthen them up a bit. I'm not sure they need it, but he asked for it. So I blasted them and painted them while they where off, and replaced the bushings with Prothane pieces.
    It ended up being about a 5/7 drop when I was done.
    He wants to get some wide steel wheels and run a stretched tire with some "poke". So I may get the P-slots back, but I kind of like the stock MKI wheels on my car for now. But I really want some Fuchs, or some other old school Porsche wheels.
  10. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Damn man you do get some random projects lol. I like how your not just a bagged truck shop. More of a versatile shop
  11. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    I love the VW caddys. I have always wanted one.
  12. Twisted Minis
    Poor Cal
    1980 Toyota
    Thats what makes it interesting for me.
  13. Twisted Minis
    Poor Cal
    1980 Toyota
    Motor is in, with new motor mounts built. Braced the cab and cut out the floor. Going to start building the rockers, then place ti over the frame and figure stuff out.
  14. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Cant wait. Good work man
  15. Twisted Minis
    Poor Cal
    1980 Toyota
    And exhaust is on. Ready to start on the floor soon.
  16. Twisted Minis
    Poor Cal
    1980 Toyota
    Mike brought his truck back to the shop to get a shift knob made. I made a one to his specs, and pressed the stock gear select emblem into the top of it flush. Took bad pics with phone, can't figure out how to email the high res version, since my phone has a 5MP camera, and they are clearer on the phone...
  17. Twisted Minis
    Poor Cal
    1980 Toyota
    Also a shot of my Golf..
    I made a knob for it too but don't seem to take pics of my stuff.
  18. Twisted Minis
    Poor Cal
    1980 Toyota
    Here is the knob in my car.
  19. andysmiley17
    andysmiley17 Veteran
    Louisville, Ky
    82 Diesel
    love your golf. keep up the great work!
  20. NotAvailable
    NotAvailable Addict
    wat exhaust did you use seth?
