hahaha i know !!!!! but iv ran into some problems with it like how in the hell did the guy that had it in that chop top get it up against the glass i lack an inch and iv cut so much to get it to fit as close as it does and idk how he did it!
probably but it is like an inch from the windsheild and i cant get it any closer iv cut all that CAN be cut
ok so guys i did some staining and id like to get some feed back on the color i chose if its not good il plane it down and start over. this is before stain so you can see the difference this is all without polyurethane. oh yea here are some teaser pics of the bed corners! it looks killer finished and with primer on it
the only reason i didnt keep it that color is because it is the same color as every other truck bed out there
ok so i stayed up 44 hours working on the truck friday and sat this is what i got done idk if i like the seat mock up or not?
yea i do too i just wish i had measured it a couple more times because when i went to bolt it in i had previously allowed for my strips to have 1/4 in bolts but i ended up using 5/16ths bolts so i ended up having to cut 3/4 of an in off one of the board and it looks goofy as ****
that damn thing is heavy as hell it took 5 of us to get it on there i may have to bump up to some 2600s on the back !
i have to its gotta be at a show this weekend on friday and saturday i worked on her for 44 hrs straight fell asleep in the cab working on the dash for 4 hrs then woke up and started working again at 8
