Post pics of your wheels.
Discussion in 'Wheels/Tires' started by Chucky, Aug 20, 2012.
  1. Smugmetal
    Smugmetal Member
    Cleveland, OH
    78 Pickup
    Finally getting my truck back together and installed my lowering springs and blocks this weekend. Might end up reorganizing the leaf springs but I kinda like the rake.. test fit my wheels before I get tires. Gonna go with 195/50x15. Wheels are no name aluminum 15x7, et-8
  2. jetas
    The height up front looks good, the rear needs more drop. Especially with the tire size you're looking at.
    Looking forward to how its all going to look
  3. Smugmetal
    Smugmetal Member
    Cleveland, OH
    78 Pickup
    That's what I was thinking too. I'll just wait and see once I get the tires mounted. I didn't have an angle grinder to cut the bolt or brackets on the springs so that's why I didn't do it at the time.
  4. jetas
    Is the bolt bad enough that it needed to be cut?
  5. Smugmetal
    Smugmetal Member
    Cleveland, OH
    78 Pickup
    I saw somewhere the through bolt for the leaf springs is too long to fit in the groove on the lower shock plate that goes on the bottom of the springs once you take out the middle leaf and it needs to be trimmed. I can't confirm since I haven't tried it though.
  6. jetas
    I can confirm that, i just drilled a hole on my shock plates rather than cut the bolt
    Dinoshonuff and Smugmetal like this.
  7. Brandan Joel Burton
    Brandan Joel Burton Newbie
  8. 78lolux
    78lolux Newbie
    Texas
    1978 yota mini
    4D50A5BD-E064-4324-84FD-0B545A293306.jpeg Old Ford 14” steelies
    Jeffery Newman and Erwin Merida like this.
  9. Drippy
    Drippy Newbie
    1998 Mercury Grand Marquis Wheels.
    16x7 / 5x4.5 bolt pattern. Wrapped in P205/55R16
  10. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    Nice. Looks perfect. I'm planning on 16s for my 1988. How big are the blocks?
  11. Drippy
    Drippy Newbie
    3" blocks
  12. MrDinkleman
    MrDinkleman Addict
    SoCal
  13. iz_danny
    iz_danny Newbie
    Pacer 320C Wheels
    15x7 offeset -6
    Tires
    165/60R15
    Steempy, Erwin Merida and Ponyryd like this.
  14. Ponyryd
    Ponyryd Enthusiast
    ^Sweet lookin truck.
    Here are mine, Superior Superstar IIIs from the ‘70s, 15x8.5, 4”backspace
    Steempy and Erwin Merida like this.
  15. 83pickup
    83pickup Enthusiast
    Phoenix, AZ
    1983 22R Long Bed 5-Speed
    Good O'l OEMs with the T-Caps or whatever they're called
    Not sure if this will upload properly
  16. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Nope, try cropping your picture down.
    83pickup likes this.
  17. 83pickup
    83pickup Enthusiast
    Phoenix, AZ
    Yep probably right, 1080p photo. Hopefully this one should work![​IMG]
  18. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    nope. What I do is I text the image to myself and that resizes it, then I save it and upload it.
  19. Rad_Logan
    Rad_Logan Member
    Love this look, what is the offset? 0?
    Ponyryd likes this.
  20. Ponyryd
    Ponyryd Enthusiast
    Probably, yes. Mine are 8.5” with around 4” offset (don’t know the exact specs but would be 4.25” max) but my truck is a different gen, stick out a bit at the rear, more at the front but I intend to find 4wd fenders to achieve equal fitment all around
    Edit: After another look it appears he posted the backspace as -16mm, this is very similar to the offset but uses the centerline of the wheel for reference as opposed to the wheel flange. When buying wheels they will usually ask you for this measurement, as opposed to offset as it’s not commonly used anymore. But offset should be 4.25” on his if my math is right.
    Rad_Logan likes this.
