Orange 1977 Hilux Restomod Project
Discussion in '1976-1983 Build-Up/Project Threads' started by RN23CB, May 17, 2020.
  1. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    There is an oil galley plug on the passenger side hidden by the motor mount you can use to feed your gauge.
  2. nottoshabi
    nottoshabi Enthusiast
    Do you have a picture of that? I have never seen anything like that in that area.
  3. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Erwin Merida and RN23CB like this.
  4. RN23CB
    RN23CB Member
    I don’t see that on mine. Only dip stick tube goes between that bracket.
  5. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    It might only be a 22r and up thing. You should have 2 oil galleys to tap off of. If you have that puck looking thing you can see on the left hand side that will be your sender that you can switch out for you new one.
    RN23CB likes this.
  6. jetas
    My block is a 22R and theres 3 plugs. Im using 2 of them. One is by the starter, other is by the motor mount and the last one is in the area of the motor mount as posted above. Il see if i have a picture
    *edit
    Passenger side of the block, the arrow is pointing at the one between the motor mount bracket bolts
    RN23CB and Erwin Merida like this.
  7. RN23CB
    RN23CB Member
    Took the starter out after work, and looked around the block for another oil port. Might be out of luck. I'm not seeing anything else aside from the one for OE sensor. Looks like I need to find a T fitting or oil filter sandwich adapter.
      File size:
      500.6 KB
      13
    jetas likes this.
  8. jetas
    Well that blows. Wouldve been cool if you atleast had the one by the motor mount
    RN23CB likes this.
  9. RN23CB
    RN23CB Member
    Got the fuel sending unit and the new pump installed. Had to cut the flange off of speedhut sending unit and drilled a couple holes to mount onto OE stem. Also finished wiring the gauges. Just have to wait for the oil psi sensor tee fitting and the adapter for the coolant temp sensor.
      File size:
      607.5 KB
      50
      File size:
      414.3 KB
      48
      File size:
      186.9 KB
      49
      File size:
      405.2 KB
      50
      File size:
      171.4 KB
      52
      File size:
      256.5 KB
      55
      File size:
      176.7 KB
      54
      File size:
      264.9 KB
      55
      File size:
      205.5 KB
      49
    Erwin Merida, jetas and nottoshabi like this.
  10. nottoshabi
    What fuel sending unit is that, I might have to change mine? Also what is the little knob you just installed in the middle for?
  11. RN23CB
    RN23CB Member
    The fuel sending unit is from speedhut. It comes with 240-33 ohms resistor. The little knob is for adjusting brightness on the gauge illumination.
    nottoshabi likes this.
  12. RN23CB
    RN23CB Member
    Fittings/adapters came in today. It was hard to find the adapter for two oil psi sensors with two different threads. The OE sensor is 1/8 BSPT and the Speedhut sensor is 1/8 NPT. Fortunately I found an adapter that has both threads from Glowshift gauges.
    Also replaced the master cylinder and repaired the cracks on turn signal lever while I was waiting for the fittings. Wanted to replace the the power booster with MR2 booster that just laying around in my parts box. Didn't want to drill the firewall, so decided against it and reuse the original booster.
      File size:
      503.9 KB
      31
      File size:
      192.9 KB
      35
      File size:
      342.3 KB
      39
      File size:
      353.5 KB
      38
      File size:
      250.1 KB
      35
      File size:
      798.1 KB
      38
      File size:
      234.9 KB
      32
    nottoshabi and jetas like this.
  13. nottoshabi
    Great job on the turn signal crack repair. I had my booster rebuilt from this moms and pops place, they did a great job the breaks are awesome. What does 1/8 BSPT and 1/8 NPT mean?
    RN23CB likes this.
  14. RN23CB
    RN23CB Member
    Thanks man! BSPT and NPT are standard thread pitches for fittings. I think BSPT stands for British Standard Pipe (Tapered) and NPT is National Pipe Thread.
    Erwin Merida likes this.
  15. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    If @nottoshabi wouldn't shave mentioned it, I really would not be able to tell you repaired the Tsignal arm.. :applause: since it's missing the toyota badge I just assumed brand new replacement! Haha fooled me! Good work man.
    It's the small details that make the bigger picture pop!
  16. RN23CB
    RN23CB Member
    Thanks for the kind words!
  17. RN23CB
    RN23CB Member
    Put everything back together and tried to test the gauges. Found out the oil psi fitting is leaking. Thought I needed to tighten a bit more while installing it, but I wasn't able to get the last full turn without one of the pressure sender hitting the oil filter. Gonna have to take it back out and figure something out. Everything else seems to work except the turn signal indicators. They work with hazard light switch on, but not with the turn signal switch:shrug:
    Anyways, so I decided to take a break from it and replaced the washer fluid/coolant overflow bottles since I had to drain the coolant to install the temp sensor. I figured it'd be a good time to replace these before filling up the radiator.
      File size:
      470.4 KB
      38
      File size:
      75.9 KB
      43
      File size:
      214.4 KB
      44
      File size:
      459.8 KB
      45
      File size:
      187.5 KB
      39
    Erwin Merida and nottoshabi like this.
  18. nottoshabi
    Ok. First the turn signal refurbish blew my mind, now the overflow bottles floored me. Where did you get those bottles and were you able to install the electrical fill sensor at the bottom?
    I have been searching for those bottles for over 5 years. I have removed my windshield wipers completely but would like to get the over fill bottle for the radiator.
  19. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    x2 where’d you find the replacement bottles? I got a universal washer but I need a new overflow
    The turn signal lever looks good. I can appreciate it because mine’s missing the plastic entirely haha
  20. Erwin Merida
    Gauges look cool! Does the speedo really give you gps? Or that's just the mileage counter?
