Orange 1977 Hilux Restomod Project
Discussion in '1976-1983 Build-Up/Project Threads' started by RN23CB, May 17, 2020.
  1. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Looks good. Cant even tell someone cut those doors up now!
    RN23CB likes this.
  2. nottoshabi
    nottoshabi Enthusiast
    @RN23CB Great job man, love the truck. Which center console is that? Can you post a link please?
  3. RN23CB
    RN23CB Member
    Thanks man! Center console is made by Tuffy. I got mine from Ebay. It's their universal 6.5" version.
    https://www.tuffyproducts.com/
  4. RN23CB
    RN23CB Member
    Got the carpet installed and started fiberglassing the kick panel speakers this weekend.
      File size:
      437.6 KB
      114
      File size:
      355.1 KB
      110
      File size:
      756.3 KB
      109
      File size:
      204.5 KB
      96
  5. jetas
    Those kick panels are going to be nice when you're done with them
  6. Perkolator
    Placer County
    1975 Hilux
    Where is your fuse panel at? That's the main reason why I haven't already installed kick panel speaker pods like you're doing. I also didn't think my boots would fit very well if I reduced the foot space
  7. nottoshabi
    Was the fiberglass difficult to peel from the painters tape? How thick did you make the fiberglass?
  8. Clay
    Clay Member
    Ohio
    93 Pickup
    This is a great project and your work looks awesome!
  9. RN23CB
    RN23CB Member
    Thanks bro!
  10. RN23CB
    RN23CB Member
    Fuse panel is mounted to the dash and upper part of kick panel. I'm not fiberglassing the whole kick panel as one unit. I'm using ABS sheets to make kick panel walls and fiberglassing speaker pods separately on the bottom corner area. I plan on bolt them together internally. You might be able to create more foot space by placing speakers higher and angle them toward the side walls. I don't know how it'd affect the sound quality though.
  11. RN23CB
    RN23CB Member
    I used aluminum foil on top of the painters tape. I would not recommend using just the tape. I used fiberglass cloth as base layer because it's easier to shape curve surface with the cloth first. Then put a layer of fiberglass mats while in the vehicle to prevent warping when I take them out. And put another layer of mats for extra strength.
  12. RN23CB
    RN23CB Member
    Thank for the kind words!
  13. RN23CB
    RN23CB Member
    Speaker pods are done and painted. Took longer than expected. Had to remake the kick panels out of plywood. ABS sheet was too flimsy to hold the speaker pod.
      File size:
      361 KB
      63
      File size:
      187.9 KB
      68
      File size:
      242.4 KB
      66
      File size:
      282.7 KB
      65
    Pearce, Ivey and jetas like this.
  14. jetas
    Looks dope
    RN23CB likes this.
  15. Perkolator
    Placer County
    1975 Hilux
    Your truck has a piece of upholstered kick panel trim there behind the speaker pod? Is that stock or did you add that when you did the carpeting?
  16. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    You do some nice work man. Dig the truck.
    RN23CB likes this.
  17. RN23CB
    RN23CB Member
    Yeah I made those out of plywood so I can use the tee nuts on the back to secure the speaker pods. My upholstery guy said he can get those upholstered the same day so I was in a rush and didn't take any pictures.
      File size:
      13.1 KB
      44
      File size:
      360.1 KB
      48
      File size:
      409.3 KB
      41
    Ivey, jetas, Pearce and 2 others like this.
  18. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    I always thought the kick panel speaker pods would be perfect. Really hate how so many people are quick to cut a hole in the door. Sucks you had to repair that but it all turned out good.
    RN23CB likes this.
  19. RN23CB
    RN23CB Member
    Since it's a long weekend I've attempted to fabricate a center console out of Napa cup holder and a shift boot I found at a junkyard. Cut the cup holder in half and using just the front half. Forgot to take picture before I threw away the back half so I found a pic on Napa website. Made a fiberglass housing for the cupholder and plywood frame around the shift boot. I'm going to bond the two using fiberglass. Hopefully I can pull it off and not look too weird.
      File size:
      17.7 KB
      64
      File size:
      28.6 KB
      69
      File size:
      17.6 KB
      69
      File size:
      449.3 KB
      65
      File size:
      197.1 KB
      70
      File size:
      520.5 KB
      74
      File size:
      553.6 KB
      71
      File size:
      343 KB
      72
      File size:
      80.3 KB
      64
  20. jetas
    Looks good man
